There are 8 processors available for this system board as shown on page 1.6 of the manual (linked below). I have copied the the processor listing and part HP part number.
Processors
6 Processor (1.5 GHz with 1-MB cache), clip, and heatsink
319952-001
Processor (2.0 GHz with 1-MB cache), clip, and heatsink*
327839-001
Processor (2.0 GHz with 2-MB cache), clip, and heatsink*
319953-001
Processor (2.2 GHz with 2-MB cache), clip, and heatsink*
352311-001
Processor (2.5 GHz with 1-MB cache), clip, and heatsink*
327840-001
Processor (2.7 GHz with 2-MB cache), clip, and heatsink*
352312-001
Processor (2.8 GHz with 2-MB cache), clip, and heatsink*
327841-001
Processor (3.0 GHz with 4-MB cache), clip, and heatsink*
352313-001
Manual:
http://h10032.www1.hp.com/ctg/Manual/c00064978.pdf
?s t?ged szeret any?d?
only the MP versions work, 2002 to 2004. matched, 1 to 8 CPU possible and huge ram 8 banks max .
the manual said, same speed and same SL stepping if 2 to 8 CPU used
RTM its all there. to read 24/7
if confused learn to read the HPE forum, on DL760 G2,
you are not the first to ask this in 19 years, sorry NOT
google finds this 15 seconds work.
https://www.hpe.com/psnow/doc/c04373935....
forum is here look ,read or ask there.
https://community.hpe.com/t5/custom/page...
What HPE supports is all that matters here, only them, and there BIOS. ALL ON THEM.
ask them,
HPE formed in 2015 so some older posts back to 2002 may be now missing so they say;./
is send it to the recycle center tagged full of LEAD.
That motherboard uses the CPU Socket 1155 LGA. Pretty much any processor for that socket should work. (Source: http://browser.primatelabs.com/geekbench2/1112660)
Popular CPUs for this board are:
(Source: http://openbenchmarking.org/linux/motherboard/HP/HP%203396)
JAMIE it is not PC it is A SERVER, real. and super old.
read the title then post.
"HP 339661-001 HP PCIx Cage DL760 G2 Mfr P/N 339661-001 System Boards"
only HP has list for that, due to the fact only their BIOS allows it, and only the newest BIOS update
allows more than the original 3 xeon in the first year published SPEC.
OP ask HPE.com for help HP enterprise web site only.
ok
not here, HP keeps QVL ,qualified vendors list a secret, why is the 8th wonder of the world. (bad)
QVL - CPU not told.
QVL ,memory is not told
they do that to over charge on upgrades from them only, marketing jockers in there Prime. (greed)
you have to pry it out of them.
the way it works at HP, is you have to ask them and beg for CPU QVL lists. based on newest BIOS updates only.
that is what you, or ask on THEIR forum, (yah think?)
As with some or all PCs and servers made, there are BIOS limits on (xeons this case) limits. a fact of life
Any?d szeret t?ged?
HP.com , or more accurately HPE.com has all your server , spec., manuals and all you need.
current.
quick spec. link
DL760 G2 (2006 year very old server, and has 4 or more processors too.
Four or Eight Intel Xeon Processors MP with fault tolerant processor power modules
https://h20195.www2.hpe.com/v2/Getdocume...
if confused, join the free HPE.com forum and ask for what processors the most current BIOS supports
they know ask them, it is a Xeon CPU.
HP retired this server is year 2015. Nov,. 1st,
2002 server (relic) 4 or 8MP CPUs possible and up to 8 banks of ECC ram, 1 per CPU. not told by you, goals.
ask at hpe.com
not told now do you have 1 or 8 CPU now, we can not guess the servers LOAD OUT.
the answer is RTM read the manual it answers this.
the manual is clear, Read it? BELOW IS QUOTE IN YOUR MANUAL NOT READ YET.
ONLY "MP" work, just those class of CPU. way bad then, 2002.
Proliant DL760 G2 Intel Xeon Processor Kits
Folder-Closed 287519-B21 HP Compaq Intel Xeon MP 1.50GHz 1MB Processor Option Kit (4 Processor Kit)
Folder-Closed 287520-B21 HP Compaq Intel Xeon MP 2.0GHz 2MB Processor Option Kit (4 Processor Kit)
Folder-Closed 334036-B21 HP Compaq Intel Xeon MP 2.0GHz 1MB Processor Option Kit (4 Processor Kit)
Folder-Closed 339072-B21 HP Compaq Intel Xeon MP 2.5GHz 1MB Processor Option Kit (4 Processor Kit)
Folder-Closed 334037-B21 HP Compaq Intel Xeon MP 2.80GHz 2MB Processor Option Kit (4 Processor Kit)
Folder-Closed 351052-B21 HP Compaq Intel Xeon MP 2.20GHz 2MB Processor Option Kit (4 Processor Kit)
Folder-Closed 351051-B21 HP Compaq Intel Xeon MP 2.70GHz 2MB Processor Option Kit (4 Processor Kit)
Folder-Closed 351050-B21 HP Compaq Intel Xeon MP 3.00GHz 4MB Processor Option Kit (4 Processor Kit)
processors cannot be mixed in the same server. They all have to be of the same speed.
same p/n and same Stepping codes intels.
(STEP OR STEPPING OR SL CODES) "versions in ENGLISH"
If you are going to use the CPU in a dual+-cpu SERVER application or machine then YOU MUST match the SL code for the new CPU with your existing CPU .
SL codes - All INTEL cpu's are also designated by a Step code or SLcode.
This is a 5 digit alpha-numberic code on the cpu itself.
Your particular cpu may have many SL codes (think of them as versions of cpus made).
In order to run dual cpu's or more in one machine the SL codes must match !
the CPu must also be compatible with HP unique heat sink not just pin counts and SL codes.
the manual is clear on this, and 8CPU ARE NOT SIMPLE AT ALL TO get going and OMG the 8 RAM banks,too.
why mess with this at home, (no business wold) 2002 junk.
ask HPE first or this here.
https://www.memory4less.com/hp-3-00ghz-x...
I'd retire it, and get a DELL R710, run RAID 6 ON 8 DRIVES.
that is a HPE server only it is no PC, it has support at HPE.com and the fourm there why in the world ask here in fixya, there is no server forum here at FIXYA.
the manuals on your SERVER tell s you all that if you choose to read it ?
intel made the CPU and they said this, and is correct (and can not be mixed)
https://www.intel.com/content/www/us/en/...
2002 is way to old now. best is move up 10 years, yah think?
2002 servers need to be retired and my guess why you got it for $20 used, and worth less.
get dell R710, win. more better but that goes without saying sure.
same answer on any PC or SERVER> even this OLD.
pin out the same and socket number same. 603?
ask them, HPE.com (why skip asking maker this nor if it needs BIOS updates)
try newest BIOS, of HP told you to for more CPU choices (microcode updates) ASK THEM.
buy what the manual told you to use, it's there to see it, I DO
RTM , RTM again RTM. HPe.com on this 2002 relic if HPE.deleted support there (read there forum for same quesitons for 19 years)
if no support on any server learn to google
google HP DL760 G2, manual
G2 means super old generation 2. 2002
