Disconnected the phone -switched it on/off no result
1. Turn on the your phone whithout sim card
2. Lock screen
3. Press sequence: Menu, Back, Back, Menu, Back, Menu, Menu, Back
4. Select Service info
5. Select SimLock
6. Check where is X
7. If X is on NETWORK and value is difrent than zero, you can unlock phone.
8. If it is zero unlock by code is NOT available. The counter is blocked.
1. Turn on the phone whithout sim card
2. Type *#*#7378423#*#*
3. Select Service info
4. Select SimLock
5. Check where is X
6. If X is on NETWORK and value is difrent than 0, you can unlock your phone.
7. If it is 0 unlock by code is NOT possible.
The counter is blocked. How to unlock Sony Ericsson W200i Walkman sim unlock net
Did you mean unlock ? did you misspell the word unlock as unblock ? If so, use unlock code to unlock your Sony Ericsson W200 from network lock. You can get it from any of the online vendors like MobileUnlockSolutions.com to unlock it .
