20 Most Recent
Sony Ericsson W350i Cell Phone Questions & Answers
Network coverage problem after select 'reset all' mode for my Sony Ericsson W350i cell phone
Try to Upgrade your Firmware using Sony Erricsson Update Service for easy ways.just
download and install Sony Erricsson Update Service,Connect your phone
to Computer using data cable,and Sony Erricsson Update Service will
found and upgrade your phone firmware automaticly.you can try download Sony Erricsson Update Service from SonyErricsson Oficial Site.and you can found The Tutorial for using Sony Erricsson Update service in
HERE
What is the NCK code to unlock Sony Erricson W350
Before you get a unlock code you need to provide the IMEI number. Every phone has a code that is as unique as a fingerprint, it
is called an IMEI number. To locate your unlocking code we need you to
provide us with your IMEI number. (You can either locate your 15 digit
IMEI number underneath your battery, usually on a label, or
alternatively you can simply dial *#06# on your phone)
How to insert Memory card into sony ericsson w350i
To insert your memory card into the phone,
You remove the battery of the phone, underneath the battery by the lower end you will see the slot where you will insert the memory card.
The direction on inserting it is shown in the phone.
Take care
Unlock W350i
If you need to unlock your Sony Ericsson W350i visit
Unlock-zone.com Here you can get your unlock code with simple unlock instructions via e-mail.So you can easily unlock your mobile within a day.
Sony ericsson w350i doesn't send sms! what's the cause?
for sending text messages :1.go to your message settings and check the message center number to see if it is correct2. call to your network operator customer care3. request the message center number...4.note it down5. go to message settings>message center number6. insert the number which is noted by you and save itthis solves your messaging problem ...Good luck
