Master
- Posted on Jul 07, 2009
Re: refridge is not cold freezer is fine
You have ice on the temp control door that has blocked air flow. You will need to pull off the back inside panel of the freezer and de-ice it or have a tech do it and test the defrost controller. That is most likely the reason for the freeze up in the first place. Hope this helps. Good luck.
