Hi switch off your iPhone holding home button then power it on still holding home and power button after 10sec relase power button but still hold home. Your phone should enter DFU mode (you will see iTunes icon on the screen) oper iTunes and then connect your phone. Now you can reset your phone to default settings. Remember all your data will be lost.
If it help please rate it.
Regards, if you still have a problem let me know, we sort it out.
Leaving an mP3 player in your pocket won't hurt it. Direct sunlight for 30 min might kill it. A pass through the washer certainly will damage it. Moisture, such as with heavy exercise, with the unit in your pocket may cause it to fail. Moisture is a problem.
The brake hose maybe bad replace it. They can claps on then self inside the hose. One work to check is have someone push the brake paddle down and release it if the rotor is hard to turn, open the bleeder vale if fluid comes out and the rotor turns freely that you problem.
Well that is DEFINETELY the place you got your music from wich caused that, Try changing the place you download music from to, LIMEWIRE... And if it still doesnt work then somethings wrong with windows media player... SORRY IF THIS ISNT ENOUGH HELP... :S
Press and hold the reset button (located underneath the hold switch) for 10 seconds. If there is still life in the battery it should start working. If not then if should begin charging when plugged in.
