A question is not stupid. Everyone needs to be sure of something sometime! :) Well if you cannot find "Send", just simply hit "Enter" on your keyboard. If unfortunately you do not have the "Enter" button on your keyboard, go to :
The keyboard has a feature (and associated button) called F-Lock. By
default, when the computer boots, F-Lock is turned on. In the F-Lock
mode, rather than sending the standard key commands for the function
keys, the keyboard sends special alternate commands (like print for F7 and save
for F8) that are configured in the iTouch program. In order to force
the keyboard to send the standard function key commands, you must TURN
OFF F-Lock by pressing the F-Lock button! Oh, and by the way, there are
no indicator lights on the keyboard, and the F-Lock button is an always
up momentary button - just like the keys on the keyboard, so there is
no way to tell what state it is in, other than by pressing it and then
pressing an F key to see what happens!
This should solve your problem. Just turn off the F-Lock Mode. Hope this helps if it does please leave a comment or a vote. Thanks JHH
Hi, thanks for using FIXYA. you have a problem with the keyboard , and the usual solution for this case is replace, but before that try with an external usb keyboard. Thanks
First, try to replace the batteries and make sure that the switch is turned ON. Then, check the wireless USB adapter if there is a small button that you use in order to connect the keyboard or mouse.
Briefly press that connect button, then hold down the connect button on the keyboard for five seconds. If that did not hep, try to connect the USB receiver into different USB ports of the computer, or might as well, try different computer just for isolation.
If the keyboard still does not work, but the mouse does, then there's a problem with the component on the keyboard that transmits signal from the keyboard to the USB adapter.
You may need to send the keyboard and USB adapter to the manufacturer for repair.
The keyboard has a feature (and associated button) called F-Lock. By default, when the computer boots, F-Lock is turned on. In the F-Lock mode, rather than sending the standard key commands for the function keys, the keyboard sends special alternate commands (like print for F7 and save for F8) that are configured in the iTouch program. In order to force the keyboard to send the standard function key commands, you must TURN OFF F-Lock by pressing the F-Lock button! Oh, and by the way, there are no indicator lights on the keyboard, and the F-Lock button is an always up momentary button - just like the keys on the keyboard, so there is no way to tell what state it is in, other than by pressing it and then pressing an F key to see what happens!
Do you have the CD drivers for the keyboard? Make sure that everything is in working order, try using this hardware in another computer to see if it works. Make sure that the usb dongle is working fine also, there should be a reset button in the bottom of the keyboard and the mouse, if the usb dongle to send the signal to the keyboard have a press on button, do so so that it can search for the signal, when it flashes the light real fast, then press the reset button in the keyboard and the mouse.
Did you replace the batteries in the wireless keyboard? If not try doing that first and then use the following info.
Normal
0
Press the Receiver button (and the lights will start
flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT
button on the back of the board to connect the keyboard to the
receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button
on the back of the mouse to connect to the receiver. Then they
should work okay.
Hope this helps. Bud
