Need to Remove and Replace the Funnel Assy P/N ADW73149901 and to do so, need to Remove the LCD (LED) Panel first. How do I do this.
Http://www.searspartsdirect.com/partsdirect/part-number/Kenmore-elite-Parts/All-Products-Parts/ADW73149901/0046/795/Model-79571053010/0583/0161000?keySuffixId=&pathTaken=partSearch&pathRender=modelComponent&documentCompId=F1003026&diagramPageId=00006
Testimonial: "Thanks Steve.....the P/N ADW....etc is the part, but, my Model Frig uses this as the replacement part but my particular model has a LED control center which must be removed before I can access what I need to do. Should I break this part, it is $395.00 and change to replace it. The Frig P/N that you referenced does not have this LED control panel, thus, you're correct and I wish it were so simple. I need to really know how to take the LEd CTL PNL off, then the balance of this repair is Duck Soup, so to say... Thanks Again... Have a great day. Anyone else out there know how to take the LED CTL PNL off ?? Thanks in advance, Ron"
SOURCE: Sears Kenmore Refrig #363-9554710 (side by side) - Remove panel on left front to access funnel guard
You will need to unplug the fridge or unplug the wires going to the dispenser from behind the grill at the bottom of the fridge.
Pop off the front cover over the switches and pop off the soft button cover that you mash to activate the dispenser.
You will see the screws that hold the dispenser assembely to the housing. remove them and the unit will slide toward you.
Post back if you need more help, I may have forgotten a step somewhere.
SOURCE: Ice and Water Dispenser Funnel
This diagram may help some.. should be a molding thats goes around outside of dispenser.. should be able to pop off and get at screws u need to get at...to remove and get at what u need too
http://www.partselect.com/Schematics/GE/00116598i01.gif
SOURCE: Needs instructions to remove the front panel to replace the microswitch near water dispenser arm
Kenmore model#10658562891 side by side refirigerator.
Need instructions on how to remove front panel to check or replace the heater that keeps Ice from freezing in the Ice chute.
SOURCE: LG Refrigerator - I need to remove the ice disp.
The dispenser cover snaps off. Look at the bottom corners of the dispenser faceplate and you may see small slots to put a small flat bladed screwdriver inside to help pry the faceplate off. This faceplate snaps on very tightly so it may seem like there are screws holding it in place, but it only snaps in.
Once you have the faceplate off the rest will be easy as you can see what you are doing and what you have to remove.
Note, if you are replacing the funnel you need to know that this part has been updated as of OCT 2005 (stronger clips to hold it in place) and it will not snap into the older funnel frame (the part it attaches to).
If the serial number for your model starts with 510KR or lower, then you will also need the updated funnel frame part number 3210JA0006S.
Hope this helps, please rate my solution.
SOURCE: I have frigidaire frs26zshb1 and need help with
Clean the Drain Tube :
Your refrigerator has a drain that leads to the exterior drain pan beneath the refrigerator. Occasionally this drain can become clogged resulting in standing water inside your refrigerator. A similar drain exists in the freezer, which when clogged results in ice build up on the floor of the freezer.
The drain is located either on the floor of the refrigerator, beneath the vegetable crisper, or in the wall behind a drain funnel.
Clear the drain by forcing a solution of water and bleach or water and baking soda into it with a basting syringe. If the solution will not flow through, slide a length of ¼ inch flexible tubing into the drain tube to push the clog through to the drain pan. Remove the tubing after clearing the clog.
If you have an ice-maker, check refrigerator and ice-maker for level:
Before leveling, unplug the appliance to avoid an electrical shock hazard.It is important for the refrigerator to be level. If it is not level, doors may not open or close properly and may not seal tightly. Also, drainage from the defrost cycle might be impaired as might the ice making cycle. The appliance was engineered based on it being installed in a level position. While there may be some tolerance for out-of-level installation, the appliance will operate at its best when properly leveled.
For me to R & R Funnel Assy, I need to remove the COVER DIODE, P/N ACQ76217901. I missed named this item when I said I needed to remove the LCD/LED plate. On the Parts Listing for this Frig.,it is listed as item #279a Cover Diode ACQ762217901...
