Http://www.youtube.com/watch?v=l1SvGJAjukY
Go to http://www.dyson.com/ and select support. Download your user manual.
Dyson vacuum cleaners fans heaters accessories spares official site
SOURCE: dyson DC 14 lost suction to beater bar/ suction to hose/stick
My Dyson DC14 had no suction...see if this works...turn the Dyson upside down...there is a length of hose that connects the bottom of the vacuum to the top, careful remove one end of the hose and check for debris...mine was clogged. Removed the clog and voila...it works. Thanks for the above info on checking the hose for cracks.
SOURCE: hi wondered if you could tell me how to change the
replaced Clutch Assy only
Clutch Assy part no:900252-04
SOURCE: how do you change the clutch assembly on the dyson
Here's a very helpful video that shows you step by step how to replace the clutch on your Dyson DC14
SOURCE: Dyson DC 25 Dyson Ball animal. The bottom brush
Two things you can do.
1- Remove the brush as if you were going to change the drive belt for it.
Clean the brush as best you can and spray some WD40 on the hard rubber/plastic
pieces at both ends of the brush. Rotate the pieces to work the WD40 into the space
between the pieces and the brush axle.
2- If you have one available, as long as the brush is off, change the belt.
This should get your unit back in operation.
If you find this solution helpful, I would appreciate a Thumbs Up from you.
Thank you.
Paul
SOURCE: Dyson dc14 Animal motor brush replacement
By the time the brushes are shot, so is the armature. You need a motor.
