Proscan 10.1-Inch Internet Tablet, Capacitive Touch Screen, Android 4.0 with Front Camera, 1.2 GHz, 1 GB RAM" Logo
A
Anonymous Posted on Oct 10, 2014
<!-- from fixya rte -->How do I use the proscan camera - Proscan 10.1-Inch Internet Tablet, Capacitive Touch Screen, Android 4.0 with Front Camera, 1.2 GHz, 1 GB RAM"
How do I fix my proscan tablet the system ui has stopped
You need to reset using a pin inserted in the hole in the back. Pressing multiple times as deep as 1 inch
How to turn camera around on a pro scan tablet
If the camera is a part of the tablet, perhaps you should try to turn the whole tablet? But if you want to switch from the front camera, to the rear camera (or v v) try the camera app, or touch the camera logo o the screen.
Why won't my new Proscan tablet charge properly?
The battery can't hold the charge. Defective.
Or the charger is defective and not outputting enough voltage.
This can be tested with a voltage tester. The charger should be outputting 5 volts.
A good purchase is an inexpensive voltage tester. Can be used for so many things.
How to fix my screen on my tablet it is craced
You can buy parts for tablets online and there are plenty of instructions out there, but the Proscan is a low-end model that it is probably not worth it.
Does a proscan tablet have a rear camera
Depends on the model.
The PLT1066 has a front and rear camera.
Proscan tablet
If you have a SD card take it out and put it back in if you don't take the battery out
My proscan will not turn on and it is charged
Your tablet may either be so low on power that it is non functional, or you may have to reset the tablet.
Top Proscan Tablets & eReaders Experts
 Mikey
Mikey
Ngoro
ADMIN Andrew
ADMIN Andrew
Are you a Proscan Tablet and eReader Expert? Answer questions, earn points and help others
