I've changed batteries on the remote, tried everything to make the color change because it's too red. The remote had fallen to the floor and that's when the red showed up. I clicked on Menu, went to the 'color' area, clicked on it and it won't open. Went down to the listing below that, they too won't open. Any suggestions?
You can buy a universal remote for 1 dollar.. option 1 however if you are using componelt input as in RGB then you have no control over your colors
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/tony_a41fa0b801734e2f
SOURCE: RCA 46" Rear Projection TV-How do you adjust the convergence colors
are you looking to correct the problem or make and adjustment
adjustments you can do from the remote once you in the menu
however if that doesn't fix your problem most likely it need convergence ic's
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
SOURCE: RCA R52WH77 convergence missing from menu
THis is very common on these sets. there is a special fuse thats cause this.. kinda hard to get rca part number 259213.. .4 amp. the reason this blows is there is bad solder connections on the flyback. so when you replace this fuse you have to resolder these connections. so if you know how to solder and can find this special fuse. it is a fast and easy repair
SOURCE: rca d52w19 convergence hell
Did you replace the convergence board or the convergence power supply board? usually one color will be a problem with the convergence board and more than one color means the convergence power supply is the problem. Ebay isnt a good place for boards as you never know if the board is good. You can get the convergence or the convergence power supply boards at the following link along with free shipping and tech support.
http://servicemanuals.vstore.ca/
SOURCE: convergence nightmare
I had the same problem, I resoldered the fyback (LL008) and changed the fuse (FL231) had my voltage back, but still no convergence. I read in the service manual that disconnecting BW001 BW002 on the Converagence Amplifier board may remove the load on the Convergence Power Supply. I unpluged the TV did remove it and turned the TV on, let it boot up and run for two minutes or more, then shut it down, waited a few minutes. Unpluged TV and I pluged back in BW001 and BW002 connector back in and turned the TV back on and it was back. Some adjustment and had had a great picture back. If this done do it your out of luck, the Convergence Power Supply and Convergence Amplifer Boards are no longer avialable. Make sure that all the flyback leads are resoldered real good.
SOURCE: phillips tv , double vision,
You have bad convergence IC's. Replace both the red and blue drive chips. They are easy to spot. They are mounted to large, finned heat sinks. The # on the chips starts with "STK-" and then there are numbers following. Both red and blue use the same part. There are 20 or so pins to unsolder\solder. These parts are available to the consumer from tritronicsinc.com. Good Luck!!
barneyluc
hope this helps
control panel administrive tools computer management device manager scoll to ports(com&lpt)right click to scan for hardware changes or scroll to monitors + to expand plug and play monitor right
click where you have options to update driver,disable.uninstall,scan for hardware changes or select properties where in the general you have the option to troubleshoot also in the driver tab you have the same options as when you first right click on monitor
control panel,display,settings you can make adjustments for more or less pixels or from the drop down list pick the appropriate level of color range or
troubleshoot also select advanced then general
dpi normal size,larger size or custom settings
hope this helps
