Model 60870 no water entering the machine and panel showing error code .10
The most common cause of a fault "i10" is closed valve on the water supply line. So this failure indicates a problem with filling of water.
Possible error causes:
Closed water tap, Inlet valve faulty, inlet hose bent, softener system clogged, pressure switch or pressure switch hose obstructed or leaking, wiring from pressure switch to printed circuit board (PCB), wiring from inlet valve to PCB and finally PCB.
Dado
SOURCE: error code AO1
Error message A01 means -Acqua stop operated due to a leak or overfill. Check if there is still water in the machine after it stop pumping. In case you still have water - your problem is with the pump or with a blockage drain line. If there is no water in the machin, it might be a water level sensor issue - stuck physically in the high level position or become defective. Try to reduced the water presure and leveled it up by the water entrance tap to the machine, it might solve your problem. Goog luck !!
SOURCE: AEG 50760 Dishwasher shows Error Code 30
there is water in the base of the macine. lean it over to the side to get all of the water out then try again.
SOURCE: error code 30
i fixed the problem by tipping the machine over slightly, as suggested by other members, about a pint of water came out the bottom and it now seems to work perfectly.
SOURCE: AEG Favorit dishwasher AAA shows Error code 10
Normally if washer doesnt complete cycle, its because the element has tripped the over temp.th/stat.(underneath), or is faulty. otherwise 1 of the 2 boards are faulty. Often the board at the bottom front left.(behind the kick panel.)is the issue. Roaches seem to accumulate on the bottom board and disrupt the circuit. If you have a mechanical timer, wiggle it side to side and note if there is a difference.
SOURCE: "LE" Error Code appears on control panel
LE is a motor error Wiring connection is OK? The Impeller of Washing Pump is locked. The rotor of Washing Motor is locked. The Blade is locked. REMEDY Check the wiring connection. Replace the cause of restriction. Replace the Washing Motor. Replace the PCB.
