you may have a pin hole in your water line to your dispenser or you could be leaking at the water valve itself on the water dispenser side. you'll have to pull the refrigerator out from the wall and look where the main water line goes into the back of the refrigerator. you will probably have to take the back off to see. be sure you put the back of the refrigerator back when you are through.
this is not a water leak ! it is the humidity in the room which collects as water and drains out at the back.keep a bucket underneath or attach a drain pipe to the outlet .
The drain hose in the back of your freezer is frozen shut. The water you see is coming from the defrost cycle. Turn off the refrigerator. Remove the floor from your freezer and remove/thaw all of the ice. Locate the drain in the back of the freezer. It may be behind the back panel. Thaw the drain until water flows freely through it. Reassemble the freezer, and you are back in business.
Leaky dispenser ??? Your water inlet valve on the back where the
water supply comes in is probably leaking. disconnect the water line coming out
of it and see if you have a slow drip. If so you need to replace the valves.
Your refrigerator needs a new water valve and possibly some new water tubing. You can find the correct part by going to sears.com and entering the refrigerator's model number in the parts search field. When you have the valve, shut off the water to the refrigerator. If you're not sure how to do that, just shut off water to the entire house. Be sure to run the kitchen sink after you shut the water off to relieve any presure and double check that the water is completely shut off.
Be sure to unplug the refrigerator before you start this project...water and electricity aren't friends! Using a 1/4" nut driver or socket, remove the cardboard or metal cover off the back of the refrigerator. Follow the water line to the water valve, unscrew the nut going to the valve, and remove the water line. There are 2 screws holding the water valve to the refrigerator cabinet; remove the screws and gently pull the valve out. Unplug the electrical connectors and remove the water lines. Take the new valve, connect the water lines and electrical plugs, screw the valve back into place, attach the water line and turn the water back to to test for leaks.
Since the valve has been leaking inside your freezer it would be a great idea to clean out your freezer and let the water tube and lines thaw. Find a place for your frozen food, unplug the unit and let it sit overnight with the doors open. Don't forget to remove the ice bin, as these make quite the mess when the ice melts. Once it's thawed, plug it back in, make sure the water is on and not leaking and enjoy!
IS your leak in the front or the back? front could be the pump seal is broke and back would be you water inlet valves. Pump tilt it back and look underneath for leaky seal and water inlet valves you need to take the back off this is a tricky but doable process. post model numbers from now on please
sounds like a leak where your incoming water line hooks to the water valves might just need to tighten the coupling or a mouse has chewed through one or both of the lines access the lines on the back and watch while some one gets water out the door to locate the leak
