20 Most Recent
Kenmore 57029 Side by Side Refrigerator Questions & Answers
I just had a professional
is the fan motor running in the freezer..?if its not locate it an turn fan blade to see if it spins freely retry the frig to see if it works ..is the coil in the freezer frozen up..?if so defrost it completly ..then recheck operation ..let me know ..good luck ..PS you may need to remove covers to get to motor //joe//
I have a Kenmore refrigerator side-by-side with
1. A door open partially will cause a frost build-up then thaw and run down to the floor. Check all doors for proper closure and educate other users.
2. An issue with an unhappy animal is quite common
3. Door switch intermittently causing a light to stay on ora fan to not run
4 Ice build up around ice door chute .
5. Water dripping into ice tray and overflowing. Replace water valve. I’m happy to assist further over the phone at
https://www.6ya.com/expert/david_dc2f9e0a44104720
Kenmore side by side model
I had the same problem. Sometimes the tray overfills and freezes in the little line that fills the ice cube tray.
I solved the problem by taking an ice pick and clearing the ice from the end of that little waterline until the water started flowing again.
Where is the defrost switch on 106.53592300
Not sure there is a manual defrost switch. Look at the link below for defrost switches for your model. On some refrigerators, if you set the temperature switch to off and unplug then plug in the refrigerator it will force the defrost mode; then unplugging and plugging again will reset the mode.
Frost Buildup in Frost Free unit.
You will have to check the defrost timer to make sure it is turning if it is working properly and you are getting power to the defrost heating element below the freezer coil it should get hot if you have a 115volts or so to the element and it does not get hot then you have a bad element
The freezer fan runs continuosly
It may be because there is some air leak into the freezer. Check if it is closed air tight. Also try defrosting the freezer. Check the fan after that. It may stop working continuously.
Freezer stopped making ice
Without any more information regarding the specific symptoms, diagnosis will be difficult. However, assuming that your refrigerator has a factory built-in ice maker, there are several items to check:
1. Is there water flow to the icemaker? If not, check the water supply line (small tubing) and make sure it's not clogged. Disconnect it and blow it out, then reconnect.
2. Check the small saddle valve on the water pipe where the tubing to the refrigerator connects. If it's full open, then it's possibly blocked with calcium buildup. Close your main water supply valve, remove that saddle valve and replace it with a new one. Before doing so, make sure that the hole in the water pipe is clear and full open. It may also have some calcium buildup. If so, simply drill it out with an appropriate sized drill bit.
2. The solenoid valve which activates water flow to the icemaker may have stopped functioning. Check the electrical connection to the solenoid valve and ensure power is getting to it. If it is, then the solenoid valve most likely needs to be replaced.
3. Check the manual for your refrigerator. It should include instructions on how to bypass the automatic function and *manually* start the icemaker.
