A
Anonymous Posted on Oct 03, 2014
<!-- from fixya rte -->How do I stop fax redial on Copystar 4035? - Copystar Office Equipment & Supplies
Bob Wescott
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
Problem Solver:
  • Contributor 17 Answers
  • Posted on Nov 28, 2014
 Bob Wescott
Contributor
Level 1:
Welcome Back:
Problem Solver:
Answers
17
Questions
6
Helped
4622
Points
19
You have to be in the fax screen and find your User install or Initial settings screen. Redial can be set there. There's a default setting that I think you can set to "0" redials. I haven't had that manual for a long time.
3 Related Answers
Anonymous
  • Posted on Feb 20, 2009
SOURCE: can receive a fax, but cannot send fax.
I was told by Xerox support tech that he thought it was the fact that we do not have a dedicated analog phone line, but the fact remains we can receive faxes but cannot send them. The only fax that will send is directly to Xerox support.???. The machine was working fine, faxing (sending and receiving), until about a week or so ago, when we had a repairman here on the printer. He told me to report the problem to our telephone repair service. He is coming out today! I'll let you know.
Oloyede Monsuru
  • 1468 Answers
  • Posted on Oct 03, 2010
SOURCE: I have a Copystar 4035
Here are two ways solution to solve the problem
Cleaning a laser printer can solve minor problems, maintain print quality, and prolong periods between professional cleanings. Clean your printer when print quality deteriorates or when you change toner cartridges.
  • Collect the supplies you need: a soft cloth and cleaning fluid made for plastic. (Water is fine in most cases.)
  • 2 Check the printer manual. If the manufacturer has provided specific instructions, follow them.
  • 3 Turn off the printer.
  • 4 Dampen a cloth with water or cleaning fluid.
  • 5 Wipe the outside of the printer, making sure that no fluid gets inside.
  • You need to know how to clean rollers to keep your printer in good working order. Proper cleaning of the copystar and the rollers will help the printer function correctly every time you use it. If the printer is not picking up the paper or the paper gets stuck in the rollers, it is time for a cleaning. Cleaning the rollers is simple when you follow these easy-to-understand steps
    INSTRUCTION 2 BELOW
  • Remove the power cord from the electrical outlet. Open the printer cover and expose the printer rollers.
  • 2 Remove the paper from the "in" tray and any paper you may have in the "out" tray.
  • 3 clean-hp-printer-rollers-1.3-120x120.jpg Hold the wet cloth against the first roller with one hand and use the other hand to manually turn the roller.
  • 4 Replace the paper in the in tray. Plug the printer in and print a test page. The rollers should take the paper from the in tray. If not, repeat the process in Step 3 to make sure you remove all of the dirt
  • please rate this solution after use
    thank you and thanks for using fixya.
    Anonymous
    • 45 Answers
    • Posted on Oct 08, 2010
    SOURCE: I got a copystar cs -4035 and i can't find the ip
    There are multiple settings..here is the manual, if that does not help, please let me know.
    http://usa.copystar.com/americas/jsp/upload/resource/17727/0/C2525E-C3225E-C3232E-C4035EENOGR1-ADVANCED.pdf
    Good Luck!
    Driver copystar cs 4035
    go to Kyocera website enter your model number and list of drivers will show even though you have a copystar machine its made by Kyocera so match your model number use km instead of cs
    1helpful
    How to fax?
    This section describes dialing and sending faxes directly using the Numeric buttons.
    note:
    • A PBX (Private Branch Exchange) is an on-site telephone switchboard. If your machine is connected through a PBX or other telephone switching systems, you have to dial the outside line access number first, and then the number of the party you are calling.
    Sending a Fax with the Numeric Buttons .
    Click here for other useful sending methods.
    1. Preparing for sending a fax.(1) Make sure that the power is turned on.
    (2) Load a document on the Platen Glass or in the ADF.
    important:
    • When sending a double-sided document, set the document on the Platen Glass. You cannot scan double-sided documents from the ADF.
    (3) Press the FAX button.
    The fax standby screen will appear.
    (4) Adjust the density (scan contrast) or image quality (fax resolution) as necessary.
    See "Adjusting the Sending Quality"
    2. Sending the fax.
    • When the document was loaded on the Platen Glass:
    (1) Use the Numeric buttons to dial the recipient's number.
    (2) Press the Color button for color sending, or the Black button for black & white sending.
    important:
    • Color sending requires that the recipient's fax machine supports color faxing.
    (3) Press the OK button.
    The machine starts sending the fax.
    note: When loading two or more documents
    • Load the next page, and press the same button as you pressed in (2) of step 2. Repeat the same procedure to scan all pages of the document, and press the OK button.
    • When you have sent the first page with the Black button, the following pages will be sent in black and white.
    When the document was loaded in the ADF:
    The machine scans the document automatically and starts sending the fax.
    important:
    note:
    • To cancel sending a fax, press the Stop button, and follow the instructions on the LCD.
    • If documents remain in the ADF after pressing the Stop button during scanning, "Close the feeder cover [OK]Eject the document" will appear on the LCD. Press the OK button so that the remaining document is automatically fed out.
    Automatic redialing
    • When sending a fax and the recipient's line is busy, the machine will redial the number after a specified interval. Auto redial is enabled by default. Auto redial can be enabled or disabled by selecting ON or OFF. Select ON to specify the number of redialing in Redial times and redialing interval in Redial interval.
    Redialing the Number Dialed with the Numeric Buttons
    1.Prepare for sending a fax.
    (4) Adjust the image density (scan contrast) or quality (fax resolution) as necessary.
    2. Select the telephone number recently dialed.
    (1) Press the Redial/Pause button.
    Most recently dialed fax number using the Numeric buttons will appear.
    (2) Use the g0016984.png (-) or g0008875.png (+) button to select the number to redial.
    The selected number will appear in the fax standby screen.
    3. Send the fax.
    important:
    Copystar Drivers
    load CD containing the printer drivers and accept the terms then follow the instructions. connect either local or network depending on the type of installation. select port where necessary USB parallel or standard TCP IP. Alternativelly go to printers, add printer and browse printer from windows
    Copystar CS-C2525E. Paper Jam error 91. No paper
    Under included device open and close the lid. Unless throw, see the condition a sensor entry and leaving the paper - can be the sensors conk. Good luck
    1helpful
    Not connecting to fax out
    Do you have a DSL or other digital phone line?
    Top Copystar Office Equipment & Supplies Experts
    ZJ Limited
    ZJ Limited
    Grand Canyon Tech
    Grand Canyon Tech
    Norman Weimar
    Norman Weimar
    Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
