20 Most Recent
Copystar CS-2550 All-In-One Printer Questions & Answers
Ii want to set the password kyocera 2550
Push the System Menu/Counter Button
Using arrow keys find the Machine Default-press enter
Use the factory set PIN (should be 2500)-press enter
Arrow to PIN# change-press enter
Using key pad choose new number-press enter then press the reset button
My copystart cs2550 puts a vertical line on copies
If it doesn't happen on internal reports or on copies made from the glass (not using the doc feeder) then it can only be on the narrow glass that's on the left of the large glass. Focus in on the area where the line shows. It may be a tiny dot, but that's all it needs to put the line down.
Copystar cs-2550 service code c6000
try this. enter "10871087" from keypad. you should now be in maintenance mode. enter "163"press "start or print" key. you should see a screen that says "execute" or it may say "reset". cursor or highlight "execute" and press "start" key. now press "stop/clear" once or twice. then press "01" then "start" to exit maint. mode. very important!! as soon as you press "01" and you see "please wait" open your front door. wait 2 secs, then close door. that should get you going unless there is a true failure. good luck and you may want to write this procedure down as it may happen sometime again.
hth,
razors
What is happening when the Copystar CS-2550
The error code C-0410 indicates an communications error with the document feeder.
It normally indicates the cable between the document feeder and copier is ether has a loose connection or the cable has a short and needs to be replaced.
It can also be an issue with the document feeder driver circuit board or the copier engine circuit board.
I hope this is helpful,
Shawn
When copying, the copied image
take a look at your paper in the drawer. the guides sometimes get shifted. also, the blue locking latch can get busted.
razors
