We've only just bought and installed our new Fisher & Paykel AquaSmart 7kg top loader and done everything that the instruction manual shows to set it up and we are set it up for a regular wash, it let a very small amount of water in and after about 10 minutes of electronic whirring, rewarded us with continuous beeping and showed an message on the LCD screen "Error Code 245 call a technician". Can anyone please help us as we certainly didn't expect to have any problems with a brand new machine?
SOURCE: water filling issue
It sounds like you have a faulty Out of Balance Micro switch(the machine now thinks it's always out of balance) you'll find this under the motor controller module (main computer module) in the top of the machine on the righthand side. Anymore questions feel free to ask. cheers
SOURCE: lights on but wont start- can I reset it model GW608 fisher &paykel
please rate my suggestion....
SOURCE: Fisher & Paykel GW612 Top Loading Washing
Hi there
That fault is the pump blocked error (no change in water level).
i have a quick and easy way to solve this problem.
first turn the machine off then tilt the machine back and lean it on something(a chair or wall), look underneath, in the top right hand corner of the plastic outer boul you will see a small pump motor it has a fan on it spin this fan and if it is hard to turn that means there is somthing stuck in the drain pump keep turning the fan and try to free whatever is stuck in the pump, then try the machine on spin again all goin well the object in the pump should come out with the drain water(doing this will not harm the machine) if the object is still stuck you will need to get the water out of the machine (bailing or siphioning will work) and tilt the machine back again and take the wires off the pump and there should be a white tab on the boul holding the pump on pull this tab and twist the pump anticlockwise about a quarter turn(you will need a few towels or a boul or bucket to catch the water) and it should come off exposing the blockage.
Hope this solves your Problem.
Nick
SOURCE: Fisher & Paykel washer GW712 won't spin
There is an issue with your drainage area. Best to remove the pump and check for the obstruction in the line or at the impellar.(If the water is not completely drained, the pressure switch wont send a low level to the timer to allow a spin).
SOURCE: fisher@paykel aquasmart WL80T65CW1 fault code245
hi my fisher & paykel aquasmart has a message saying fault 49 what does this mean?
