20 Most Recent Fisher Paykel Eco IWL16 Questions & Answers
Have replaced the drain pump and diverter valve.
for safety purposes, all repairs should be performed by an authorized service technician. first, perform systems check in order to diagnose any problems. the tech sheet is usually located under the control panel.there may be an obstruction in the recirculation system. coins small objects may have blocked the recirculation. beware coins can work as a valve if it is in the right place. remove the basket to ensure that the pump bellows is cleaned and clear. if the pump has been leaking then the pump and electronic control need to be replaced as a pair. once replaced the control need to get programmed for the specific model.
12/11/2017 12:45:35 PM • Fisher Paykel... • Answered on Dec 11, 2017
6answers
Fisher and paykel 7.5 smartdrive washing machine, no power
If there is power and all your lights are lighting up but you get no responce from the machiene eg no spin, water filling, wash cycle or drain then it will be the sensor for the lid it will have coroded but this is an easy fix , I hope this helps
6/29/2015 4:44:26 AM • Fisher Paykel... • Answered on Jun 29, 2015
Fault 16 light 00010 000
Your motor controller board is faulty and has no motor movement.
3/29/2014 2:03:32 PM • Fisher Paykel... • Answered on Mar 29, 2014
Fisher & Paykel IWL 16 shuts off during all cycles.
I says power cut restarting in 10 seconds I'm sorry, it is the board, the switch mode power supply is dying. Every time it starts to do something it power cuts. Best to get a new motor controller board, Quote the 6 digit part number under the bar code to get the right part.
12/15/2013 10:07:32 PM • Fisher Paykel... • Answered on Dec 15, 2013
Machine keeps stopping between cycles, turning power off wall for hour seems to reprogram and start machine to next cycle then stops again
It sounds like an 11 series machines, When power supply gets warm it stops. You will need a technician to fix the power supply in the brown board.
12/15/2013 1:11:30 AM • Fisher Paykel... • Answered on Dec 15, 2013
Fisher and Paykel Kelvinator Pride 5.5 Smart Drive 9
You need to read the error code and tell me what lights are on 0d178d8e-bec6-4c9d-a189-8f7fc18d947c.jpg
12/15/2013 12:55:13 AM • Fisher Paykel... • Answered on Dec 15, 2013
I w 812
Here are some details for fault code 37 37. (00100101) Pump Blocked Error (No change in the water level) While draining, the water level reading from the pressure sensor has not changed for over 3 minutes. There are three likely reasons for this fault. One is that the drain hose or the pressure switch hose has been squashed or kinked and the pump out rate has been dramatically reduced. The second possibility is that the pump is partially or fully blocked. The third is that the pump is not operating due to Motor Control Module, wiring or pump failure. This fault could also appear if the machine is pumping to an unusually high head of drain hose or into an extended length of drain hose. The fourth possibility is a diverter valve fault or blockage, water level is not altering as the diverter is stuck in the recirculation mode, giving the module the appearance the pump is not lowering the water level. Primary Source: Action:1) Pump System. Check that the drain hose has not been kinked. 2) Check the length of the drain hose and try to reduce the length if excessively long. A 39.36in / 1 metre extension hose of the same diameter fitted to the existing drain hose is the maximum allowable length. 3) Check for open circuit windings in the pump. (Note: Pumps are fitted with a thermal cut-out, which will reset on cooling.) 4) If the basket is empty of water, remove the pump from the pump housing and check that it is not blocked. Also check the drain hose is not blocked. 5) If the basket contains water, then service the pump from the top of the machine by removing the top deck and inner basket. Bail out the water, remove the pump cap and hood and clear the restriction. Secondary Source: Wiring. Action: Tertiary Source: Action: 1) Check the pump harness is connected correctly to the pump. 2) Check continuity of the pump harness. Motor Control Module module. Activate the pump by operating the machine in spin mode. Check the pump is rotating. If it is not operating, and Primary and Secondary checks have been performed, then replace the Motor Control Module.
12/15/2013 12:51:51 AM • Fisher Paykel... • Answered on Dec 15, 2013
The drain pump on my F&P IWL16 is leaking water. I've had the pump replaced 3 times, during which, the new control board with fuse bypass was installed to prevent the board from blowing again
The pump may not be seating tight against the bucket, There are four bolts on the gal plate you can tighten to make pump seat tighter on the bucket.
12/15/2013 12:21:56 AM • Fisher Paykel... • Answered on Dec 15, 2013
All lights flash display reads "power out self reset in 10 seconds".
Display reads power cut restart in 10 seconds The motor controller board has a switch mode power supply problem. Best to get a new motor controller board Or a technician to look at it. Look at the 6 digit part number under the bar code to get the right part for your machine.
12/14/2013 11:27:11 PM • Fisher Paykel... • Answered on Dec 14, 2013
Machine will not power on.
If the display lights do not come on at all then more than likely the Motor Control Board is dead, a replacement can be expensive so if your machine is over 5 years old think about replacing it. Remember you get 2 years warrany on all F&P machines. Most importantly make sure you are getting power to the machine by trying something else is the power outlet like a hair dryer.
11/21/2013 3:55:09 AM • Fisher Paykel... • Answered on Nov 21, 2013
IWL16 leaks from the top during spin cycle, black specs on clothes
Try running running it MT on smaller load setting a few time,s then do a smaller then you had been doing load of close. I belive yr getting or have got.water.past the.shaft seal,s. So maybe wth smaller load.inclueding.water setting you may see some change i.e. no more black speacks. Sorry.about my spelling. Am.still new
11/10/2013 4:53:11 PM • Fisher Paykel... • Answered on Nov 10, 2013
0answers
FISHER & Paykel 6.5 Smart Drive - No display lights
You need to get hold of a multi-meterand check the resistance of the pump, It should be 33ohms or close to it, the pump is part of the power circuit and the machine will appear dead if it has blown or is unplugged, If the machine was running without the earth wire to the pump connected and the pump had a fault/blockage there is a very good chance that it has blown the motor controller module. It requires the earth to provide a fault path to earth.
3/5/2012 4:25:20 PM • Fisher Paykel... • Answered on Mar 05, 2012
0answers
'LD' on display and lid closing won't get the washer started
Hi just read your posting.Now I know you supplied the model number in your posting but could you please supply the name of the machine which should be written on the control panel.Is it an ENDURO or an ESPRIT --etc--?Please reply with additional information and I can help you rectify this problem.Looking forward to your reply.
7/31/2011 5:06:32 PM • Fisher Paykel... • Answered on Jul 31, 2011
Fisher Paykel Eco IWL16 Logo
85 questions posted
Top Fisher Washing Machines Experts
Paul Bade
NOEL
NOEL
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Fisher Washing Machines
Most Popular Question
fisher paykel 7 5 smartdrive washing
  • Washing Machines
