Cant pair earbuds to phone
SOURCE: pair my samsung bluetooth to my blackberry cel phone ,
i found out that if you turn the bluetooth off and then turn it back, while turning it back on hold it until solid blue light and then try 2 connect with your blackberry i jus got mine and threw my instructions out. and i did this and it worked and if it should ask for a passcode i used 0000.
SOURCE: how can i pair my samsung bluetooth headset to
turn off the head set then press and hold the on button until the blue light stays solid blue.
search for device on your new phone and add device code is 0000
SOURCE: how do I pair my WEP 200 samsung bluetooth to my
Your phone MUST have the bluetooth on and discoverable. When it is press and hold the power button on the WEP200 until the light turns on steady should be 5 to 10 seconds. With this done, use your blackberry to search for a new device, should be in the bluetooth menu. It should find the headset. Your phone will ask for a password enter "0000" (four zeros) then press pair or enter. It will take a few seconds to connect. Your phone will automatically connect to this headset when you power it on. Don't forget to turn the phone back to un-discoverable when done. I hope this helps.
SOURCE: pair bluetooth em227 with my phone
Be sure the the headset in in 'Pairing' mode.
When in pairing mode, the light should be flashing red and blue or have a steady blue.
The put most headsets in pairing mode, turn headset OFF, then hold the power button until it goes into pairing mode as discribed above. Then you can discover it with your phone. Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
