Very likely the video card went bad. Try changing monitor, also see if you can boot in safe mode, when the computer is booting up press on and off the F8 key, if a menu is presented, select Safe Mode. If the computer boots up and you see the screen normal, then it could be the video driver.
Could be any number of things... Bad cable, intermittent connection, bad video card. . . not enough info here to diagnose the problem
I have a similar problem:
I have a Compaq Presario SR2010NX desktop computer. Recently, very occasionally, the computer would freeze and the screen would scramble. It almost looks like someone chopped up the picture on the screen. Then we would have to manually shut down the computer and restart. It would always work fine afterwards.
Yesterday the computer did it again. It restarted fine but when my boyfriend tried to install a new mouse the computer froze again and the screen went scrambled. Well this time it did not start back up. I tried to unplug the computer from the wall and restart but that got me to the COMPAQ screen and then the computer froze again and the word compaq was doubled all the way down the screen. We continued to try to start it in PC recovery but it would get the the program and freeze. I actually got it to run once but I couldn't see what it was doing because the screen was scrambled.
Now we have restarted it so many times that it will start up, light turns green, and stays green. The computer sounds like its starting up and it seems louder than normal. The computer doesn't do anything and the screen is black. The lights on the keyboard do not turn on but the light in the mouse does. The CD drive will light up and run as well but nothing happens after that. I can't see the cursor and the keyboard does not work.
I opened the computer up, cleaned the dust off, tried to re-install my old RAM and that did not work either. I disconnected the CD drive but that did not work. Tried to start the computer with nothing plugged in except mouse, keyboard and monitor and that did not work.
I don't know what to do! Help!
