20 Most Recent Dell OptiPlex GX620 PC Desktop Questions & Answers
the optplex 620 doesn't meet the windows 7 requirements but would run as you have found. your options would be to add newer pci soundcard
or try the windows 7 or vista, driver from http://www.radarsync.com/drivers/id282355/soundmax_integrated_digital_hd_audio_driver_for_Windows_7_x64
GL
Jammer
Dell OptiPlex... | Answered on Oct 30, 2019
I don't think you can install 8gb of ram into that desktop. If the processor fan is too loud check it for dust or any other obstructions. If there aren't any try replacing the fan - it could be a bearing in the fan.
Dell OptiPlex... | Answered on Apr 28, 2018
The amber light within the Power Button indicates a PSU or Motherboard fault. If you have changed the PSU and it is a known good unit, please check the plug that connects to the Motherboard again. Assuming that this is ok, it may unfortunately be that the motherboard capacitors have blown (a well documented failiure).
Dell OptiPlex... | Answered on Nov 02, 2017
Memory Error Take the Computer to a Shop could be your Memory Sockets are not working correctly
Dell OptiPlex... | Answered on Oct 17, 2016
Dell OptiPlex... | Answered on Jun 27, 2016
That would indicate overheating ... do the usual checks = blocked vents, dust clogging the CPU heatsink etc ..
Then the less likley, such as a loose fan cable, loose CPU (or other) heatsink etc. (you might want to reseat the CPU heatsink ...)
Still no luuck ? Well, it's time to start unplugging things .. reduce your system to the minimium, maybe some plug-in card is upsetting things ..
If 'none of the above', then it's possible the power-supply is sending incorrect voltages or the motherboard has failed in some way (eg the temprature sensor under the CPU chip)...
PSU's are cheap, so replace that before replacing the motherboard
Dell OptiPlex... | Answered on Mar 30, 2016
Here's a video Dan Shibata suggested as a solution to your problem from YouTube:
Dell Optiplex 330 Running Windows 7 64-bit
Dell OptiPlex... | Answered on Mar 02, 2016
Virginia smith,
Did you forget the password? Are there others that you share this computer with? System passwords are inputted in the computer by the users. Dell does not put any passwords in computers. Dell also does not have any generic passwords that will get you into the computer. You will need to find out the password, search the internet for password recovery websites, format and reinstall Windows or click the link below and view other ways that may be helpful in recovering the password.
http://bit.ly/1SQkaX7
Thank You,
Dell-Jesse L
Dell OptiPlex... | Answered on Dec 10, 2015
Yes, it can, but it needs to be a low-profile PCI board. Here is a link to a site that can sell you one. There are other sites as well.
low profile firewire card Newegg com
Dell OptiPlex... | Answered on Sep 19, 2015
Display Properties should have a way to rotate the screen. You can also enable/disable the hot keys there.
Dell OptiPlex... | Answered on Aug 05, 2015
Three possible conditions of fan noise.
A condition of functional computer component parts
first, an overloaded memory due to several programs installed on the desktop bacground
second, a disk in the driver compartment generating fan energy to cool the system. Caused during movie displays using the computer disk drivers, or burning disks with the disk driver. Third, an extensive use of the computer requires more fan energer cooling capacity.
solving fan over tasking
1. free up the computer memory requirements by removing malfunctioning software programs
2. perform a computer defragmentation located by clicking START, PROGRAMS, ACCESSORIES, SYSTEM TOOLS, selecting the options disk defragment
a. defragmenting redistributes files into spaces producing an effeccient memory function requiring least fan capacity.
3. perform a computer malfunct programs cleanup by clicking START, PROGRAMS, ACCESSORIES, SYSTEM TOOLS, selecting the options of disk cleanup
a. the disk cleaning removes remnants of fragmented files making performanc effective requiring least fan generate energy
conditions of disfunction condition in a component part
1. a broken component of the computer system impeding the fans effective performance
a. a foreign object in the fan compartment causes loud noise
b. a broken fan due to over heating
c. a manufacturers condition of prior computers that performed on fan cooling rather than heat sunk dispensing and obsorption
contact expert technical support
Dell OptiPlex... | Answered on Jun 12, 2015
You want a USB connection between your computer and your phone? Why? To transfer pictures? To access the Internet through your phone?
Who's your carrier? What's the make and model of the phone?
Dell OptiPlex... | Answered on May 04, 2015
If windows 7 you need to burn a repair disc & run it. Go to Maintenance, creat repair disc (use one CD & mark it with Dell gx62 on top, repair disc run first on bottom)
Restart your computer and hold down escape, F1 or F2 to get into the settings in the CMOS. You must chang the boot order of your startup. In CMOS use arrows to right to Boot to change to CD ROM then HDD so your CD will go into repair before starting the HDD. Each CMOS is different but usually you can use the f5 or f6 to change the order and f10 to exit & save the setting. Restart your computer after you put the repair disc in & that should repair your start up.
I’m happy to help further over the phone at https://www.6ya.com/expert/wynn_5ba0205233ebfc15
Dell OptiPlex... | Answered on Jan 25, 2015
You need an actual Dell windows disk to reload to a new hard drive as it will flash the associated drivers and boot sequence to the RAM. Nothing else works with DELL!
Dell OptiPlex... | Answered on Oct 27, 2014
https://www.slimwareutilities.com/slimdrivers.php
Dell OptiPlex... | Answered on Oct 10, 2014
Boot the PC and as soon as you hear the 1st beep keep pressing the F8 key, that should bring up the start menu options
Dell OptiPlex... | Answered on Sep 04, 2014
could be any number of things... Bad cable, intermittent connection, bad video card. . . not enough info here to diagnose the problem
Dell OptiPlex... | Answered on Sep 02, 2014
Try to remove the dust buildup in the back of the tower. If necessary unscrew it and vacuum clean.
Dell OptiPlex... | Answered on Aug 28, 2014
Dell OptiPlex GX620 PC Desktop Logo
425 questions posted
Ekse
Alun Cox
Thomas F. Schneider
View Most Popular
OptiPlex Dell
  • OptiPlex Dell
Most Popular Question
will support ieee 1394 firewire card
  • Computers & Internet
