20 Most Recent Samsung SyncMaster 214T 21.3" LCD Monitor Questions & Answers
To determine if the LCD monitor or the video card/computer is faulty, connect the LCD monitor to a working computer. If the LCD monitor does not get a Windows image using this computer, then the LCD monitor could have a faulty inverter board or a faulty CCFL lamp.
Parts and service are available from LCD Parts, their WEB site is :-
www.lcdparts.net
If the LCD monitor is OK then the fault is with your computer.
Samsung... | Answered on Apr 19, 2016
The flickering is caused by a power supply board that can't stabilize the output voltages. This type problem is caused by failing capacitors. If you can solder then you should be able to do the repair yourself. Check out our step by step repair guide at: http://www.ccl-la.com/blog/index.php/samsung-214t-repair/ If you don't want to do the repair yourself we do offer a repair service for this model. The repair runs $30 plus shipping. You can setup the repair service at: http://www.ccl-la.com/blog/index.php/service-request-form/
I hope this helps, if so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Samsung... | Answered on Mar 27, 2014
Those aren't easy to find (if at all). Your best bet would be to ditch the original stand and get a VESA compatible mount or stand kit. You can usually get them for cheap on monoprice.com
Samsung... | Answered on Oct 24, 2013
Yes,
A flickering screen indicates the power supply is not properly filtering the output power. This happens when the capacitors on the power board start failing. Here is a link to a repair guide that shows how to dis-assemble the unit and what to look for and replace on the power supply board. The repair guide also has videos showing the process.
I hope this helps, if so please rate my solution.
BuddyMc
Samsung... | Answered on Jan 15, 2012
Flashing or flickering is a common indication of failing capacitors in the power supply board. The fix is very simple and just requires replacing 5 capacitors on the board. They will need to be soldered. Here is a link to a repair guide for the Samsung 214T units. http://www.ccl-la.com/blog/index.php/samsung-214t-repair/
BuddyMc
Samsung... | Answered on Jul 09, 2011
either some capacitors were not replaced properly or you have nor replaced some of them.
The capacitor you need to replace will have a bulged top(swollen).
Try and change the refresh rate of your monitor by following these options--
1.) Right click on your desktop.
2.) Select Properties.
3.) Click on the Settings tab.
4.) Click on the Advanced button.
5.) Open up the Monitor tab.
6.) Manually increase the Screen Refresh Rate to 75Hz(60Hz if it is max), which is measured in Hertz
Please check out the complete procedure with pictures on this link---
Samsung 215TW Capacitor replacement
Samsung... | Answered on May 22, 2011
It does the same when attched to another PC?
Otherwise look for bad caps with domed tops first.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Samsung... | Answered on Apr 15, 2011
for some reason it's going into "protect mode". you need to have it looked at by a service tech..
Samsung... | Answered on Jan 07, 2011
Leaking capacitors on power supply in monitor atleast replace the 2 820u & 1 330u 25v
Look for electrolite ozzing out
Samsung... | Answered on Dec 08, 2010
Faulty power supply most likley, extended warranty?
Samsung... | Answered on Nov 19, 2010
Look for as caps as shown here:
http://s807.photobucket.com/albums/yy352/budm/Samsung%20Syncmaster%20214T/
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Basic LCD monitor troubleshooting guide:
Learn about bad caps: Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Samsung... | Answered on Nov 13, 2010
Your monitor has a failure in the back light power supply, this is a common problem in this model after a few years of use. The repair is easy and only takes about 20 minutes but it does require soldering to replace 5 small parts called capacitor in the power supply. We have the step by step repair guide posted on our web site at: http://www.ccl-la.com/blog/index.php/samsung-214t-repair/ If you don't want to do the repair yourself we do offer a repair service, this runs $32 plus return shipping. You can get more information on this service at: http://www.ccl-la.com/blog/index.php/service-request-form/
We hope this helps, if so please rate our solution.
CCL Tech
Corporate Computer
www.ccl-la.com
Samsung... | Answered on Oct 19, 2010
Samsung SyncMaster 214T 21.3" LCD Monitor Logo
59 questions posted
Top Samsung Computers & Internet Experts
Ekse
ThaMp3Doctor
ThaMp3Doctor
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
SyncMaster Samsung
  • SyncMaster Samsung
Most Popular Question
214t flickers radidly
  • Computers & Internet
