SOURCE: oil drain plug
Drain plug is not necessary. Remove the dipstick and tip the mower to the side the dipstick is on and use the dipstick tube as a drain.
SOURCE: yard machine 21'' push mower runs 2 to 3 seconds cuts off.
Tip the mower up on it's side with the dipstick tube on the down side and collect it in a suitable container. The gas you can do the same. When I drain old fuel, I mix it with a lot of fresh fuel and a bottle of dry gas then run it in my car.
SOURCE: what kind of oil for a husqvarna riding mower?
Yes Briggs and Stratton recommends sae 30 in most all their engines even overhead valve (OHV)
Kohler uses 10w-30 in most of their overhead valve engines
Briggs has their own bottled oil with their label and additives and can find at lowes
Kohler the same
SOURCE: I have a YTH1542 husqvarna riding mower. Will not stay running
make sure the small vent hole on top of the gas cap is not clogged. Mine did the same thing and then I found mine was packed with dirt.
SOURCE: how much oil does it take?
If your mower has a briggs&stratton motor you will need to put in 1 and a half qts. of 30W oil in it.
