SOURCE: OS 10.4.11 Won't Sync Calendars w/iPhone 3G
Make sure that in the sync settings you don't have Outlook turned on or something. If that is on, and you don't actually have anything to sync in outlook (or don't even have it), then this can result in it sitting for a long time, if not forever. You might also try to check and make sure that a dialog didnt pop up and somehow get minimized to the dock or something as well. I had a similar issue with my ipod touch and all it ended up being was a stupid check box under the calendars sync settings.
SOURCE: sync iphone 3g calendar w/outlook 2007
In itunes go to syncing options and make sure contacts and calender are selected! then resync! hope this helps! Merry christmas!
SOURCE: Lenovo S series ideapad will find my dlink router no network addr
Generally if you can see the D-Link then everything is trying to talk. Would have to know if the d-link is new out of the box or is part of an existing setup. If the d-link has been part of the network I would suggest that you don't have the security settings correct. If you right click on the network icon and look at the send received numbers. If received is zero then your problem is you don't have the security key (WEP or other type)) setup. If you are getting recieved numbers you may not have the DHCP setup in the d-link. DHCP assigns the numbers to the computer but the d-link has to have this turned on in some models others it is by default.
If both your laptop and dlink are not new and specifically about a year old then I would also suspect that the dlink has died or is dieing on you. If you have had periods of disconnects or slow jerky network acess then these are signs of the dlink having problems. The wireless part tends to go after a year or so while the wired portion probably still works. When they go they are annoying as they work then they won't and so on.
That is you next step to try is to plug in your laptop direct to the wired connection on the dlink to test if the problem is the wifi portion of the dlink. If it connects your problem is the wifi and you probably will have to replace the unit. Next plug it into the cable modem and see if the problem was in the dlink itself.
SOURCE: How do I sync my Yahoo contacts and calendar with my iphone?
By syncing your contacts you need to connect the ipod to the computer when itunes loads you need to click on contacts then click on import from you then select where all your contacts are from in your computer which will then all be transfereed to your ipod
