Uniden BC60XLT-1 Handheld Scanner Logo
A
Anonymous Posted on Jul 31, 2014
How to enter codes on uniden bc60xlt handheld?
John
Level 2:
  • Uniden Expert 510 Answers
  • Posted on Aug 01, 2014
John
Uniden Expert
Level 2:
Answers
510
Questions
Helped
193835
Points
885
Hi, first, you can only listen to analog radios on this scanner, so if you local or state public servants went to digital, you are out of luck. You can still receive National Weather Service, most railroads, ham radio operators and any small town police and fire that have remained on analog VHF and UHF. Do a Google search and you can get the instruction book for the radio. As far as channels, search for Radio Reference dot com and search for your state and county. That will list the channels to enter into your radio. Good luck and have fun.
5 Related Answers
Anonymous
  • 8 Answers
  • Posted on Apr 10, 2008
SOURCE: code number formy scanner
http://www.uniden.com/pdf/BC60XLTom.pdf
Anonymous
  • 3600 Answers
  • Posted on May 29, 2009
SOURCE: i cant tune my Uniden BC60XLT-1 Handheld Scanner
you need to know the frequency you want to listen in on like local fire police and sheriff and ambulance channels you can go to bear-cat web site and they have a company there that will give you the scanner frequencies in your area code so you can store then to listen to them, you can also get the Freq. for the 1.2 million UN peace keepers in the U.S. as well. However you need to im put the frequencies manually and you need the manual so go to the web site for the uniden it's http://www.uniden.com and read how to store the freq. codes in the scanner. it will tell you how many you can store I think it's up to 10.
Anonymous
  • Posted on Jan 05, 2010
SOURCE: how do i program my uniden bc60xlt scanner
I found the manual on line and followed the directions
Jason
  • 218 Answers
  • Posted on Feb 25, 2010
SOURCE: uniden bearcat bc60xlt-1 channels wont unlock
Channels have to be programmed with a frequency before the scanner will allow them to be unlocked. The L/O indicator should automatically turn off once a frequency is in memory.
Anonymous
  • 2761 Answers
  • Posted on May 19, 2010
SOURCE: BC60XLT Handheld Scanner: I am looking for tech specs on BC60XLT...
Specs can be found in the scanner's operating manual which you can download/print here:
Bill B
How to enter a frequency?
Programming for the BC60XLT-1 is fairly simple, and it's best explained in the factory manual that you can download and print, at no cost, here:
http://www.uniden.com/pdf/BC60XLT-1om.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
www.RadioReference.com
Bill B.
Listening in since the 60's
2helpful
How can i program my scanner i've got the codes but dont know how to program it
To enter a known frequency (they're not codes) into your scanner:
- Power the unit ON
- Press the MANUAL key
- Enter a channel number (01 - 30)
- Press MANUAL
- Enter the frequency, including decimal point (e.g., 438.065)
- Press E
More detailed programming is outlined in the scanner operating instructions, which you can download and print here:
Bill B
Bill B
2helpful
30 channel 10 band radio scanner uniden 8c60xlt
You listed your question under the BC60XLT, which is a 10-channel scanner. With 30 channels, I'm guessing that yours is actually a BC60XLT-1. To program a known frequency into it:
- Power the scanner ON.
- Press MANUAL.
- Enter the channel number that you wish to program.
- Press MANUAL again. (NOTE: Instead of entering the channel number, you can press MANUAL repeatedly to advance to the desired channel.)
- Enter the frequency, including the decimal point.
- Press E to store the information in memory.
- Repeat the above for other channels.
More detailed information can be found in the scanner operating manual, which you can download/print here:
If your scanner is a different model, pleasd let me know.
For a comprehensive database of active frequencies in your area, visit:
Bill B
Need freq for scanner for albany ga
Press Manual,enter the channel number, then press MANUAL, enter the FREQUENCY you want including the decimal point, press E to enter,if you make a mistake,press CLR to erase,....You can get the frequency's for your state at www.RadioReferance.com ...hope this was helpful...
How do I program my Uniden Bearcat BC60XLT-1 Programmable Hand-Held Scanner
Press Manual, enter the channel number, then press manual again, enter the frequency you want including the decimal point, then press E to enter. If you make a mistake, press CLR twice to erase.....Get your frequencys for your state at www.RadioReference or www.RadioFreq.com hope this was helpful...
1helpful
I have a uniden bearcar scanner lost manual how do i enter codes model bc55xlt
http://www.fixya.com/support/p223851-uniden_bc60xlt_handheld_scanner/manual-13709
hope this helps...Good luck!
3helpful
3answers
How do I Program my Uniden Bearcat BC60XLT
i am having trouble programing frequencies into my scanner i need help!!!!!!!!!!!!!!!!!!!
Top Uniden Radio Communications Experts
John
John
eradiostore
eradiostore
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
