Steam Generator Issue. Call for service, you can't fix these yourself as they are fully computer controlled. Maintaining them is a cost of doing business.
https://www.rational-online.com > en-xx > manuals
PDF
The status of the preheating temperature is displayed in red and blue. The end of a cooking process is indicated by the flashing Self-. Cooking Control® button.
The list of codes is on page 105. Code E34 is simply listed as contact customer service. Which is not really all that helpful in diagnosing the problem. Have you tried to reset the oven? Disconnect the power cord for 2-3 minutes and trying again? If this doesn't work, given the general code, you should call the customer service number in the manual.
Hope this helps.
Hi, error 12 is displayed when the oven pcb is too hot, check that the air filter is clear and the cooling fan is running. Also it could just be the software, if it is an older oven and has the original software then it may just need upgrading by someone who knows what he/she is doing.
Hi, It very well could be the ignitor. Sometimes they work at first and then will not open the gas valve later in cycle. You can set the oven to heat and watch the ignitor. If it glows and the gas will not ignite in 30 to 45 seconds, the igniter is getting weak. I jope this helps.
Please let me know if I can assit you further.
