Behringer Eurolive B212d-wh Active 550-watt 2-way Pa Speaker pair Logo
A
Anonymous Posted on Jul 21, 2014
Why does the fuse keep blowing? - Behringer Eurolive B212d-wh Active 550-watt 2-way Pa Speaker pair
Bill Hansen
Level 1:
  • Contributor 2 Answers
  • Posted on Oct 13, 2019
Bill Hansen
Contributor
Level 1:
Answers
Questions
0
Helped
967
Points
6
I had this happen on 3 F1220As, all in a stage setup, after a power blackout. The main power amp, an ST TDA7293, was bad in all three. Replaced that and it worked. However, it "thumps" more when turned off now.
richard vreede
Level 2:
Sergeant:
  • Expert 432 Answers
  • Posted on Oct 12, 2014
richard vreede
Expert
Level 2:
Sergeant:
Answers
432
Questions
6
Helped
112424
Points
621
Hmmmmm. Are we talking about your internal or external fuses; Do they blow at the moment you put power on it, and what about the switch of the used voltage ?.... And was it straight away , since when you bought them; Then just send them back, Second hand?, too bad, you're ripped off .
Abs fuse keep blowing what should I look for
30A main fuse keeps blowing up on my 2001 thunderbird - Triumph ...
www.triumphrat.net > ... > Hinckley Classic Triples
Nov 13, 2014 - Posts: 33. 30A main fuse keeps blowing up on my 2001 thunderbird ...Have a close look where the loom passes the headstock & inside the headlight shell..... Battery can't reach out and fry a fuse if it isn't attached somehow. ... main fuseblowing (06 Sprint ST ABS), Lumpy, Maintenance & Workshop Talk, 7 ... Fuse 8 keeps blowing? - Wont start...
Apr 4, 2015
Blowing ignition fuse in the rain
Jul 7, 2013
Main 30A battery fuse blowing
Aug 3, 2008
Legend headlight fuse keeps blowing
Jun 10, 2007
More results from www.triumphrat.net
15a fuse keeps blowing ANY IDEA"S ???? - ApriliaForum
www.apriliaforum.com > ... > Aprilia 650cc - 50cc Motorcycles > RS250
Jun 19, 2009 - 13 posts - ‎9 authors
Ive had my bike at a workshop for the last 4weeks getting a freshn up . ... If the fuse isblowing that quick you should be able to find it quickly , probably .... eliminated the dash and reduced the amount of things you need to look at. .... SL750 / Dorsoduro 750 · 2008-2014 Mana 850 and Mana 850 GT-ABS.
Fuse Keeps Blowing - Electrical - VFR Discussion
www.vfrdiscussion.com > ... > Motorcycle Maintenance > Electrical
Dec 29, 2015 • Motorcycles
My crank fuse keep blowing what cause it to blow
Ignition Switch / Starter Fuse keeps blowing. - CarGurus
www.cargurus.com > Questions > Ford > Focus
CarGurusAug 14, 2010 - Ignition Switch / Starter Fuse keeps blowing. - I own a 2002 Ford Focus, 2.0l SPI engine. 5-speed manual trans. Recently bought from a friend's ...
Mazda 626 ac fuse keeps blowing
Try unplugging the compressor then put in a new fuse. If the fuse does not blow, the problem may be the clutch on the compressor.
Cop fuse keep blowing on my 2000 lincoln ls
I just got a lincoln ls v8 and fuse #12 cop's is missing what is this fuse for thank you
3answers
It keeps blowing fuses - two 12 inch cls subs 1
sounds like the audio stage riving the channel has a short circuit on it.need to go through the amp stage
3answers
Starter fuse under the hood keeps blowing....the factory deck was replaced by a new deck...every since then the ignition fuse keeps blowing..
the new radio install is causing this if the power was taped into the starter system. rec. removing wires then try to see if you can blow your starter fuse
2answers
Toyota Camry 1994 Main Fuse keeps blowing
-if your fuses are blowing
-the problem is in the wiring
-because if too much amperage flows through the fuse will blow
-there's probably a short to ground somewhere or high resistance after the fuses causing it to draw more amps
Keep blowing fuses
hi, make sure you are using a time delay fuse and not a regular fuse. this may be the reason why the fuse keeps blowing out on your dryer.
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
ADMIN Andrew
ADMIN Andrew
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
