When i fill the washer it leaks water out the front on the bottom
SOURCE: washer leak in an estate washer
i have Had 3 estate washers leak on all four corners....there junk went with ge instead......estate washers are horrible
This is a good question; what brand of washer machine do you have?
Is it front or top load?
Leaks water from the front door, from where you load the soap or from the back or bottom?
If it is from the front door it could be the gasket, if it is from where you load the soap it's the same soap clogging the fill hose, if it is from the back it could be the hoses or the fill valve, if it is a top load and you see the water liking from the side or bottom, then, if it is from the side the fill hose is your problem if it is from the bottom then it could be the seal from the drum or just a leaking pump.
Please be more specific
