20 Most Recent GE WHRE5260E Top Load Washer Questions & Answers
I have a Kitchen aid dishwasher (KUPD01ILBS3). I
Replace gasket.
9/29/2017 4:25:51 PM • GE WHRE5260E Top... • Answered on Sep 29, 2017
My washer fills with water but does not agitate. Does drain and spin cycle works. How do you begin disassembly of washer to access inner workings?
Hard to answer your question without model # to see how it's designed.
8/28/2017 2:08:09 PM • GE WHRE5260E Top... • Answered on Aug 28, 2017
2answers
GE Washer stops during cycle
CHECK THE SENSOR SWITCH underneath the washer where the door closes , it could be loose or damaged, hope this helps AJ
4/30/2015 2:31:23 PM • GE WHRE5260E Top... • Answered on Apr 30, 2015
Where can I find a diagram of a ge whre5260e? I'd like to find the agitator.
When the machine agitates, it stops working. The belt has a lot of tension at this point. stops working?? does it trip shutdown what your info is far too sparse to make any definitive view if the belt and rotors gears {egg gear} has failed you would hear it grinding so can you hear the motor running ie youll hear the water circulation motor pump usually one motor is used for both if this is the case and the motor runs then its the gear system thats wrong check the agitator motor start up capacitor hasnt failed the info you give isnt good enough
2/9/2015 9:14:11 AM • GE WHRE5260E Top... • Answered on Feb 09, 2015
My washing machine smells sour and I don't know how to cure it.
I used 2 quartz of Clorox bleach running a full load without clothes. After that the odor has gone for good. Try that.
4/14/2014 10:05:55 AM • GE WHRE5260E Top... • Answered on Apr 14, 2014
Getting no water spin is fine. I have a split going to a steam dryer and it gets water. It is a type 111
The water valve is either faulty or clogged. Remove the hoses and check the screen in the water valve on the back of the machine.
2/5/2014 12:09:38 PM • GE WHRE5260E Top... • Answered on Feb 05, 2014
Washing machine water level sensor not working
You can do one or 2 things. Drain the machine, disconnect the pressure tube going to the level switch and reconnect it. Check the actual switch itself and make sure it is working and also check that it hasnt fallen off and shorted itself against the frame of the washing machine. I see these switches fall off inside a lot.
12/6/2013 8:52:04 PM • GE WHRE5260E Top... • Answered on Dec 06, 2013
I change out my controll circuit board put new one in and all they lights are flashing model WHRE5260E1WW
there should be a key sequence to program the new board as this board will fit a lot of units with different features,and you need to set the program for your particular machine,there should be an instruction sheet on how to accomplish this with the new board
4/28/2013 1:18:54 PM • GE WHRE5260E Top... • Answered on Apr 28, 2013
2answers
Ge WASHER WHRE5260E shakes violently and makes
the cloths in the washer needs to be ballance... too much load on one side
1/1/2013 6:00:54 PM • GE WHRE5260E Top... • Answered on Jan 01, 2013
My knob oN THE START SWITCH SPINS AND DOES NOT ENGAGE
Sounds like a broken know try pushing in with some force or pull out with some force if both fail the know will have to be replaced
9/26/2012 8:46:38 PM • GE WHRE5260E Top... • Answered on Sep 26, 2012
GE WHRE5260EWW washer sounds like a jet when it spins
On a modern washer there will be an Engineers Program which is invoked by a key combination press. You can control all the functions from there and do tests. 1200 rpm is the Ideal speed for a washing machine for good reasons... Ask any Woman this !!Google your Model with Engineer Program etc.We have a range of Service Manuals at: www.spotless-service.com and adding many new ones everyday.
8/29/2012 2:44:00 PM • GE WHRE5260E Top... • Answered on Aug 29, 2012
Ge washer whre5260e1 wont spin all the time
easy fix. replace the motor: VideoService guide If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
3/6/2012 2:36:32 AM • GE WHRE5260E Top... • Answered on Mar 06, 2012
GE WHRE5260E Top Load Washer Logo
150 questions posted
Top GE Washing Machines Experts
Virgil Watts
Steve Sweetleaf
Steve Sweetleaf
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
GE Washing Machines
  • GE Washing Machines
Most Popular Question
washing machine water level sensor not
  • Washing Machines
