20 Most Recent
Whirlpool Estate TAWS750PQ 27-Inch Washer Questions & Answers
Washer smells after load
First thing to try is to get affresh washer tablets. They are a new product from whirlpool designed for front loaders to keep the smell out. They also work great for top loading machines. They are about ten dollars a pack. Read the instructions and run the washer through its cycle and the smell get better. The longer you use it, the smell should go away.
WTW4950XW2 how to remove agitator?
Pull off dispenser cap if it has one or top cap. Underneath will be another cap to remove. Finally there should be a 7/16 bolt to remove and then pull off.
Washer will not fill up with water
if the washer lights up and when u push start button it should click if it does then I think u have a water inlet problem. also check where supply hoses hook up to washer take them off and make sure that rhe screens on value are not blocked u can clean with old tooth brush. Hope this helps
Repair belt
does not have a belt change the motor coupling
Want wash or spin
I need more info about the machine. Does it make any noise when the start button is pressed, if you can hear the motor turning then more than likely your belt is either after slipping off the drum or breaking. you should be able to access the belt either by the back of the macine or the top to see if the belt is broke or just after slipping. Another problem it could be is that the capacitor in your macine could have blown. To test this you press start, open the door of the machine, spin the drum by hand and close the door before the drum comes to a stop, if the drum continues to rotate after you close the door then you know it is the capacitor that is blown, this needs to be replaced either by an electrician or a specialist as it is possibe to connect the capacitor wrong and the result would be the capacitor exploding damaging your hand. Always plug out the machine before opening the top or back of the machine.
Machine will rinse but wont always spin
Possible that the program controller is not proceeding sequentially to the program cycle and so there is a missed spin at some point. Check the connections from the program controller, before it can be suspected.
Not draining properly
Hello, here is a great link to check out everything you can think of on
your washer repair and trouble shooting. Make sure you really check out
the different areas to click on on this site..
Here is the link. I hope this helps you, mike
http://home.howstuffworks.com/how-to-repair-a-washing-machine.htm
