Husqvarna 28cc Hand Held Blower HVH 125B Logo
A
Anonymous Posted on Jul 13, 2014
Husqvarna problems coil good no spark
charles beach
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Husqvarna Master 1,917 Answers
  • Posted on Sep 17, 2014
charles beach
Husqvarna Master
Level 3:
Renaissance:
Answers
1917
Questions
Helped
570514
Points
3010
Look for bad safty switch
I have a husqvarna 129L .I have no spark checked power switch its good so I replaced coil still no spark. Any suggestions?
Disconnect the kill wire at the ignition module (coil). If you then have spark, then likely the kill wire is shorted to metal somewhere along its length.
Husqvarna with a kawasaki engine only running on one cylinder
This typically indicates a bad spark plug or coil on one side. Possibly the wiring going to the coil or from the coil to the plug. Use a spark tester to test for spark on that side.
Other less fun problems are the valves on that side need adjustment.
Husqvarna troubleshooting
Test the coil with a spark tester. Also, clean the area behind the coil where it mounts. There must be good contact (ground) for the coil to product spark.
1helpful
Husqvarna 61ff spark plugs problems
The early 61 has a coil on the right side, and an electronic pack at the left side of the flywheel, if there is no spark it is nearly always the electronic pack playing up, make sure the wire to the coil from the box is a good conection under the small screw, the later 61 has a single peice electronic unit, so this will need to be replaced.
Husqvarna 359 - No Spark
remove the side cover and then the small wire to the coil check for spark again if still no spark the coil is bad if you get spark back the problem is the switch or wiring
1helpful
Have Husqvarna YTH 150, good gas battery charged starts runs for 30 minutes and stops?
is it loosing spark when it dies?like the coil is bad or there's a nest under the cover and the coil is overheating
2helpful
2answers
Husqvarna 455 rancher Starts fine and runs great for about 5 mins. Stalls and wont restart until cold. Problem than repeats
Try removing the fuel cap for a moment to see it can be restarted immediately. If this works, check the fuel tank vent for plugging problems. Also, check for spark at the plug when it dies--if no spark, try a fresh plug gapped at 0.020". If nothing, the ignition module may be failing with heat. Good luck!
Power Tools
how many turns should be on the air and oil screws on the carb of the husqvarna c61 chain saw
Oct 08, 2008 • Garden
2helpful
Power Tools Chain Saws igniton problems
according to husqvarna the ignition coil is no longer avalible for this saw,the service bulliten says that every thing needs to be changed to make this saw work again.everything includes the flywheel,crank shaft,ignition coil,woodrif key,nut and washer.husquvarna will not let me order the origional coils.i do have a copy of the service bulliten if you would like a copy.just e mail me and i'll send one your way........
Top Husqvarna Garden Experts
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Thomas Perkins
Thomas Perkins
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
