SOURCE: Epson D120 printer carriage goes to the left and stays there.
Yes I understand that, I think your proilem maybe that there is dirt/ ink on the slide bars. ( Sublimation ink ias notorious for imparting a residue)
So take a cloth and clean those metal rods that the cartridges slide along. They should reveal a lot of dirt on the rag. Then use some wd 40 or light sewing machine oil on another rag and wipe on wipe off. They only need a very slight amount.
I hope that is of help to you.
Please rate my help++++Thanks for using FIXYA
SOURCE: epson 1280 ink carriage making noise and not printing
If you are getting a 'carriage jam' error as soon as you turn on your Epson printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Fix 'Carriage Jam' : Open Door, clear carriage jam,
and then press OK to continue' error message
Turn off the printer and open it to see where the paper is stuck.
Manually move the carriage toward the opposite side.
Check the paper path and remove any piece of paper or any other object that is stuck in the path.
Reconnect the power cord and turn on the printer.
http://www.fixya.com/support/t5192341-epson_photo_1400_paper_feed_ink
SOURCE: Epson R320 carriage jammed
SOURCE: Ink carriage started make some horrible noises.
Examine the belt that powers the print head, see if it is excessively sloppy, check the head moves freely along the print head bar, if it snags, there is damage to the bar or the print head holder is worn
TBH, I'd bury it if there is any wear as replacement parts are expensive compared to a new printer
Testimonial: "Answer was quick, to the point. Tried the recommendation and was 'exactly' as mentioned. Leave it to the GURU. Thank you!"
