SOURCE: Water fill valve on Kenmore series 90 top fill washing machine
To get into the machine read THIS first.After you have accessed the innards then you can easily remove and check the water valve. . Hook the water up to the valve. Get a suicide cord and apply 120 vac to each of the coils and see if they open.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: Dishwasher will not fill
EE,
The most likely culprit in a "no fill" scenario (especially after you've replaced the valve) is the Overflow preventer. It's designed to kill power to the valve if the water level gets too high. It does this by floating up as the water level rises.
Open the dishwasher door and remove the lower rack. You'll see it in the tub on the left side (the round thing that looks like a little hat). If it's stuck in the up (overflow) position, you won't get water. Raise and lower this device a few times... you should hear the "click click click" of the kill switch. Now just make sure it's in full down (ready for water) position and fire up the dishwasher. You should get water now.
If this helped, please rate this solution as "FixYa". BUT if this didn't fix the problem, don't rate it just yet. Write back and we'll go a little deeper into a diagnosis, OK?
SG
SOURCE: Kenmore washer 90 series will not fill up with water
You can shut off the water, then remove the hoses to see if the screens on the fill valve are gunked up. This is much easier to do than to replace the valve. I think you'll have sucess on that route :)
SOURCE: kenmore 80 series washer will not fill. replaced
You will have to have an electrical test done. If it's not filling, that means there's no current getting to the fill valve. Have a qualified technician do an electrical test. But also, have him test the timer, too!
