Light on machine tells me to clean filter .Have cleaned the filter and the area inside the machine where the filter sits .Is there any where else I need to clean ? When attempting a cycle the dryer stops and red light tells me again to clean filter. Happens on all cycles except cool cycles.
Based on just giving the model number 57700 ... I assume this is a condenser dryer from AEG??
If so ... in addition to cleaning the fluff filter ... make sure the water reservoir is totally empty and that the condenser is clean. You may have already checked these. If so ... then the issue could be where ever your sensor is ... and I am not sure where that is
Good luck on your troubleshooting
SOURCE: Cleaning the filter / wash cycle not running properly
you need to put the machine on its front and look under it and you will see a black rubber it gos to the pump and to the drum well the drum one has to come undone with a flat head screw driver and if that's clean then put it back properly when you have done that and you have cleaned the pump out if the machine still done work then your pump has gone you will get one from ebay don't for get to wright down your model number ok good luck
SOURCE: Bosch Tumble Dryer Filter Light
Helenhjb, there is a couple of things I can think of that can cause this. The filter is one. The mesh on the filter is extremely fine, so get a steady stream of water running, then put the filter under the water. If the water doesn't run straight thru, then wash the filter with detergent until the water does run straight thru. If this works fine, then your issue may be that the door switch is set too far back and when you do heavy loads, the laundry pushes on the door and shuts down the dryer. On the Bosch, any time you open the door during the cycle, it will flash the lint filter lamp. The only other thing I know of usually has an E:01 flashing on the display is restricted vent. Hope this helps.
SOURCE: spinning cycle
usey only takes about 2 tbs soap ather than that bad main board make sure you have cold water going in washer
SOURCE: AWM8143
FA is the emergency shutoff switch that detects when water is pooling underneath the machine -> a leak.
"Check float switch under machine, empty any water from catchment tray, check for water leaks or oversudsing".
SOURCE: Turning no Heat, clean filter lights on while turning
usually heat element or high and low limit sensors need changing, check vent lines are not plugged or 220 breaker if split breaker is only tripped on one side?
