SOURCE: my zyxel 660 hw works fine for 10 minutes, then starts disconnect
If the same thing is happening with the USB WIFI on the PC. This sounds like a problem with your PC rather than your router. Is your antivirus / spyware scanner up to date? If not up date it and run a full system scan. Also you should check to see if your Firewall is up to date, and that the wireless network you are connecting to is included in the safe zone area of your firewall.
1 more thing if you are using a Thrid party firewall (i.e. Norton, Zone Alarm, McAfee, Etc.) Make sure Windows Firewall is deactivated (in Conntrol Panel) having 2 firewalls on can lead to random problems
SOURCE: how to bring back the router function of zyxel P600 w/o password
You can simply reset the device to factory defaults. There's a reset button at the back of it. Hold it down for 30 second with the power on. That will reset the unit back to router function.
SOURCE: im using zyxel p600 : problem from router then to
Only 1 PC is able to go online. check the IP address on that PC.
and make sure that it is a private IP address. You have a switch also.
why do you need a switch if you have only 2 computers in the network.
If you have a router then you can connect both the computers directly to the router.
Click Here for more info about networking.
