My washer is stuck in the spin cycle. the washer is off and it keeps flashing spin
SOURCE: Whirlpool Duet stuck on spin cycle
Press 'end of cycle' for over 3 seconds. Perhaps you have to check your filter, maybe clogged.
SOURCE: Washer stopped during spin cycle
Hello, try to checked the pump filter, and the pump is actually
working. then I would suspect a
draining problem.
If filter clean and pump works fine then it could be a control module fault.
if this were the case, then it would probably be wiser to purchase a
new washer.
Thanks
SOURCE: my whirlpool washer flashes f35
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!
