RCA RCR311B Remote Control Logo
f
frank gama Posted on Jun 03, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Not changing color only green color on screen
Lawrence Oravetz
Level 3:
  • RCA Master 10,558 Answers
  • Posted on Jun 07, 2014
Lawrence Oravetz
RCA Master
Level 3:
Answers
10558
Questions
Helped
2700489
Points
29284
The red and blue tubes are bad. Time for a flat screen. Parts for your TV are very expensive.
How do I change the text color from green?
Go into the settings control of your PC and look for text size / colour etc. Change the colour to what you want.
After lamp replacement, why is picture still green?
it seems like the green was not defective before you replaced the green. remove the red =no change in the screen color, that could be bad. put back red, then remove blue=screen color changed, blue is good, hope you got the idea.
Green screen
1.) Press and hold down the "Menu" key until the manufacturer's logo appears on the screen. This could take up to a minute or more. Release the "Menu" key when the logo appears.
2.) Immediately press the "9," "8," "7" and "6" keys in this order. Press the "Enter" button on the remote to enter the "Service Menu" screen.
3.) Press the "Menu" button to go to the second of the two "Service Menu" screens. Press down on the "Down" arrow until you highlight "Color Calibration." Press the "Enter" button to enter the "Color Calibration" screen.
4.) Select one of the color bars on the screen. Adjust the color by changing the values of the color bar by pressing left and right on the "left" and "right" arrows on the remote. Repeat this procedure with the other color bars as well. Stop adjusting the colors when the green cast is no longer present.
5.) Press and hold the "Power" button on the remote to exit the "Service Menu" and save the adjustments you have made.
Now turn the T.V. off. When you turn it back on it should reflect your personal preference.
Read more: http://www.ehow.com/how_7302235_fix-tv-screen-green.html#ixzz2fM4Pfcki
Read more: http://www.ehow.com/how_7302235_fix-tv-screen-green.html#ixzz2fM3rDVkt
Read more: http://www.ehow.com/how_7302235_fix-tv-screen-green.html#ixzz2fM3hkBLp
Read more: http://www.ehow.com/how_7302235_fix-tv-screen-green.html#ixzz2fM3VlPaY
Read more: http://www.ehow.com/how_7302235_fix-tv-screen-green.html#ixzz2fM3H5rYm
Pioneer bdp 51fd picture color is green
check screen options. sometimes you can change the primary color's intensities(it looks stupid at 100% for all). You might have red a little low making yellow and blue show up greenish on the screen.
Logon Change
Enable Log-On Screen
Windows, by default, is set to show the Welcome screen during startup.
To enable the log-on screen to show, go to "Start" menu and select "Control Panel".
In the control panel, click on "User Accounts".
In the "User Accounts" dialog-box, click "Change the way users log on or off" and uncheck the "Welcome Screen" option.
Click "Apply Options" to save the changes.
Change Log-On Screen Background Color
To change the log-on screen background color, go to the "Start" menu and click on "Run".
In the run dialog-box, type "mspaint" as the name of the program to "Open".
Click on "OK". In the "Paint" window that opens, select "Colors" from the main menu and click on "Edit Colors". In the "Edit Colors" dialog-box, select "Define custom colors".
Here pick the color of your choice and note down the "Red", "Green" and "Blue" values.
Write down these values somewhere.
Click "Cancel" and close the paint window without saving. Now, go to the "Start" menu, click "Run" and enter "regedit" as the name of the program to "Open".
In the registry editor, navigate to HKEY_USERS\.DEFAULT\CONTROL PANEL\COLORS and double-click the "Background" string.
In the "Edit String" dialog-box that opens up, change the values in the "Value data" field to the red, green and blue color values that you wrote down (e.g. 75 78 173).
The default value will be 0 78 152. Enter the values in the correct red-green-blue order, separated by a space. Close the registry editor and log off to see the changes.
Put Image in Log-On Screen Background
To put your favorite picture in the background of the log-on screen, click "Start", then "Run", and type in "regedit". In the registry editor, navigate to HKEY_USERS\.DEFAULT\CONTROL PANEL\DESKTOP and double-click the string "Wallpaper". In the "Edit String" dialog-box that opens up, enter the full path and filename of the image that you want to use as the background. The image must be in .bmp format. Click "OK" and close the registry editor. Log off to see the changes. hope this helps
Green color and screen size is smaller
If screen size is smaller, is the size changing when turning channels ? If so then you have to go into settings and change the aspect ratio to either Normal (then all channels will appear the same). If you choose a size then all the channles will appear that way. Your color wheel could be going out if the green color is not working or has problems "meshing" with the other colors. Hope this helps
Color problems with LCT2701TD
you may be lucky and its a lose wires on the tcon board if not then the tcon board is on its way out, this is on the back of the screen and is feed by the av board. this controls the signal into the screens output.
3helpful
2answers
Warped Picture, Separated colors
Each color (red,green & blue) has an amplifier IC (STK-).
When there is a convergence issue,the first step is change both
IC's for reliability. Then check for open fuses devices,usually
pico fuses.Then re-check convergence alignment.......T.
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
