Nokia 6680 Handheld Logo
A
Anonymous Posted on May 29, 2014
How to fix my aircard 770s - Nokia 6680 Handheld
How can i use my 881 sierra wireless aircard to get online with my ps3
Download and install Sprint's SmartView. Select the download for your computer's operating system. Follow the installation wizard's prompts to properly install SmartView. The aircard should be connected to the computer during installation.
Restart the computer. Leave the aircard connected during the restart.
Double-click on the Sprint SmartView icon on the desktop.
Wait for the program to initialize and recognize the aircard, then click "Connect." Sprint SmartView should activate the aircard automatically.
Open a browser window to access the Internet.
I NEED DRIVER TO INSTALL MY SIERRA WIRELESS AIRCARD 775.
Your SIERRA WIRELESS AIRCARD 775 product is a discontinued product, you probably can get the archived drivers @ SIERRA WIRELESS " Archived Downlopad" http://archive.sierrawireless.com/Default.aspx?Folder=\AirCard\
Hope it helps.
Trouble connecting to the internet w/PS3 using an cricket aircard
the best thing for you to do is get a cable and attach it to the internet port. the cricket aircards have a tendency to fail or stop working entirely
Aircards
Go to device manager and try to reinstall the drivers.
I do not have a router because i live in the country and the only way i could go was a sprint aircard and i wanted to see how i could use that to connect the internet to a ps3
You will need a second Wireless LAN Card or USB Wireless device for the P3, then install all SW for the devices, set BOTH computers to have the same workgroup name (Rt click My Computer, Properties, Computer Name, Change) then reboot both boxes.
Log onto the Aircard box
Goto to Start, Settings, Networks and Settings
Double click Aircard
Click Properties
Click Advanced tab at the top
Click Allow other to share
Click settings
Pick your poison
Add any extra you need
Click OK 2x
Goto start, Run and type cmd
type ipconfig /all
write down settings
Goto P3
goto Start, Settings, Networks and...
Double click the WLan icon
click properties
On the top scrollbar find TCP/IP and highlight it
click properties
change IP to Use this IP and set to same as Aircard +1
Massk is same
Gateway is same
DNS is same. If no DNS make this PC same as Aircard IP
type ipconfig /all
write down settings
Type PING www.xxx.yyy.xxx (IP of Aircard to see if P3 can SEE it
if OK, then open Browser and come to this site ;-)
If not OK (Ping timeout)....
go back to Aircard PC
Click Start, Settings, Networks and Settings
Right click Aircard
Click Properties
Click Advanced Settings
write down all these
WLAN protocol: 802.11a,b,c,g....
Channel
SSID
Encryption type (changge if P3 does not support)
Password (copy to .txt file and save to memstick or floppy)
Go back to P3 and do same
Then click scan for hosts
find your Aircard name
Click connect
copy/paste ot type in Password from Stick or floppy
try open browser again
Easy!
Connection to PS3 w/ Sierra 881U aircard
you may need to get a cradlepoint router, which is used aircards and cell phone connections. this should help with the connection on the PS3
2answers
Sprint 595 air card
This has been a common issue, so far no fix found
Is there a way i can connect an aircard to a netgear wireless router?
In the Aircard window, on the top you should see either commnication or networks. In networks tell it to search for all networks. When you open the manager, it should show your network and the Aircard network.
Please remember to rate all users who assist you for free :)
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
How do I uninstall windows on my acer aspire 5315?
make sure system is off . remove the aircard. turn on u computer .Well u can use system restored from windows and set it to the first day they installed it. and reinstall driver first for u sprint aircard then shop down computer and insert the aircard. :)
Top Nokia Computers & Internet Experts
k24674
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
