Your touch pad should do the trick.
They are called "Gestures". They are set to active by default. If it's not. Go to "Control panel > click "mouse" and find "touch pad". There you will find "Gestures". Activate it.
1. Put two fingers on the touch pad and try to move both fingers up or down. Learn how to scroll up and down.
2. Move those fingers side ways. This should do the "Horizontal" scroll.
There are others, like:
Put one finger stationary and rotate the other. This rotates the orientation of the object.
Try it and good luck.
SOURCE: mousepad on the laptop--
Go into your control panel (if your on windows). Load the mouse settings control. You can customize the features of your touchpad.
SOURCE: display problem
Quickly and repeatedly press each key on the keyboard.
Due to the impact, one of them may have become "stuck" in the "down" position, and thus is interrupting the start-up of your computer.
SOURCE: My dell vostro 1000 laptop's display ain
if i read this right, when you power up the laptop you get fan spin but no display ?, if you just get fan spin and the green power light and nothing else the you have a motherboard failure, if you get LED activity and it seems to be working but you only have no display the its more likely LCD failure, if you DO get activity try this : power off the system, press power button while holding down the D key, this will run the LCD BIST SELF TEST which will run through full colour screens if fails this test you will et a beep code, please bear in mind you will only be able to run that test if you get LED activity, if you dont have activity then the motherboard needs replacing
SOURCE: dvd will not eject from slot drive of dell vostro 1510
Restart your computer and enter set up bios. Try ejecting your dvd rom from there... it that doesn't work, get a pin and insert it in the pinhole on the dvdrom whuile pressing the eject button... that should do the trick!
The scroll on your laptop is controlled by the trackpad installed on the system.
If you are having problems with the scroll on your laptop's trackpad, there is something you can do before you take it into a computer repair shop.
Updating the driver to the trackpad will enable the scroll if it is not working at all.
Once the driver is updated, your scroll should work again.
You can access the driver through the Device Manager on your laptop.
Click the "Start" button, then click the "Search" option.
Type "Device Manager" into the search bar and press the "Enter" button.
Click on the "Device Manager" icon from the menu, then scroll down to the "Track Pad" icon on the left side of the screen.
Click on the icon, then click the "Driver" tab at the top of the window. Click the "Update" driver option from the window.
Wait for the new driver to install on your computer.
This should take about two minutes to complete.
A window will appear telling you that the driver has been installed.
Put your fingers on the touchpad to move the mouse around on the screen.
Hope this helps.
