20 Most Recent Dell Vostro 200 PC Desktop Questions & Answers
2answers
How to create hotspot in dell vostro 200 ?
Deepa christopherUnfortunately, you cannot make the computer a hotspot without a wireless card installed. You could add a wireless card and then search the internet on how to setup the computer as a hotspot with the OS installed on the computer.Thank You,Dell-Jesse LDell Social Media and Communities
7/25/2016 3:26:18 AM • Dell Vostro 200... • Answered on Jul 25, 2016
How to restore dell vostro 270 computer back to factory settings
You need to use the restore CD's that came with the PC. If you don't have them, then you'll have to buy them from Dell's website.
1/15/2016 6:53:41 AM • Dell Vostro 200... • Answered on Jan 15, 2016
Wireless switch
There is no switch for wireless connections on a tower. If you have a wireless card installed in the computer it is on as long as the PC is powered up. If you do not have a wireless card in the PC, then you'll have to get one and install it in an unused slot on the motherboard.
1/15/2016 6:22:44 AM • Dell Vostro 200... • Answered on Jan 15, 2016
Dvd rewriter
can you explain your problem?
11/6/2015 2:08:10 PM • Dell Vostro 200... • Answered on Nov 06, 2015
Dell vostro 200 powers on fan, but have a black screen and cannot run is safe mode or boot up
It sounds like the Video card has suffered a catastrophic failure. Remove & go to a parts store or order from someone like Frys.com or ebay or Tigerdirect.com If you don't know how to use someones computer to look up "How to change the Video Card on a Desktop PC" & you will find a video of how to. I’m happy to help further over the phone at https://www.6ya.com/expert/wynn_5ba0205233ebfc15
1/25/2015 1:24:02 PM • Dell Vostro 200... • Answered on Jan 25, 2015
How to reset admin. password on a dell vostro 200 desktop computer running linux
Have you tried rebooting and repeatedly hit the F2 button?
9/20/2014 1:32:11 PM • Dell Vostro 200... • Answered on Sep 20, 2014
Forgot password for windows vista business
Install windows 7 if your computer is ready for win 7
9/11/2014 6:58:32 PM • Dell Vostro 200... • Answered on Sep 11, 2014
Factory reset dell vostro 200 running windows 7
Do a restore if you have a recovery partition on HDD.If not-reinstall OS.
7/30/2014 6:38:53 PM • Dell Vostro 200... • Answered on Jul 30, 2014
Cannot change channel on my Dynex DX-L26-10a TV
Try checking the signal strength then run the scan again.Checking the DTV signal strength You can check the DTV signal strength to determine if you need to adjust your antenna or digital cable input. The higher the signal strength, the less likely you are to experience picture degradation.To check the DTV signal strength: 1.Press MENU. The on-screen menu opens. 2.Press < or > to highlight Channel, then press v. The Channel menu opens. The DTV signal strength is shown at the bottom of the menu. 3.Press EXIT to close the menu.
6/28/2014 1:32:48 AM • Dell Vostro 200... • Answered on Jun 28, 2014
How do you reset dell vostro 200 to factory settings using the disc?
by using the disk you will not be able to restore it to factory settings. try making a system recovery disk instead.
6/2/2014 2:55:13 PM • Dell Vostro 200... • Answered on Jun 02, 2014
Dell 200 vostro reboot disk
Reboot to what?
5/6/2014 3:06:27 AM • Dell Vostro 200... • Answered on May 06, 2014
Dell Vostro Desktop PC- Wireless Internet suddenly stops working.
Reload drivers.
5/6/2014 1:26:00 AM • Dell Vostro 200... • Answered on May 06, 2014
Why does my Dell Vostro 200 keep beeping?
Defective memory can cause blue screens, no video, beeping sounds. It's possible that you have a defective memory stick.
5/3/2014 1:57:10 AM • Dell Vostro 200... • Answered on May 03, 2014
I am running Windows XP Home edition. I changed some setting in the "Setup" using the F2 key, and then like an idiot changed something in the categories I think called "Bios"
There are several ways to reset your Bios. But until you are locked out of it, there is an easy solution. You need to reset your bios. The location and wording of this option varies for every different BIOS.It will typically be called "Reset to Default", "Factory Default", "Setup Defaults", or something similar. It may be located in one of the tabs or it may be an option listed near the navigation buttons. What you need to do is reboot your PC, press F12 or DEL until the bios screen arrives. Then you need to just navigate to 'Defaults' or "Load Defaults" or "Load Reset to Defaults", select it, press yes and select "save and exit". The PC will restart and the BIOS should be reset to original setting.
4/12/2014 7:35:14 PM • Dell Vostro 200... • Answered on Apr 12, 2014
0answers
2 beep after 4 second 2 beep again and again 2 beep
Probably RAM issue. Try reseating the RAM sticks, if that doesn't work, remove one at a time and turning on PC. If you only have one RAM stick, then it could be faulty, so if you can borrow or have access to another RAM stick, then try that.
1/20/2014 7:42:17 AM • Dell Vostro 200... • Answered on Jan 20, 2014
Dell Vostro 200 PC Desktop Logo
176 questions posted
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
View Most Popular
Vostro Dell
  • Vostro Dell
Most Popular Question
speakers plug in dell vostro
  • Computers & Internet
