20 Most Recent Dell Vostro 1015 Laptop Questions & Answers
Dell vostro 1015 which originally had window 7 but shows windows was not genuine
Try this program:http://www.softpedia.com/get/Tweak/Unins... and disable automatic updates: START-> CONTROL PANEL-> AUTOMATIC UPDATES -> CHOOSE THE OPTION -> Turn off automatic updates <- ....
7/25/2016 7:35:33 AM • Dell Vostro 1015... • Answered on Jul 25, 2016
2answers
I need a free 25 digit product key for activating
There is no free key. Ya gotta pay for it from Micro$oft.
4/20/2016 6:10:34 AM • Dell Vostro 1015... • Answered on Apr 20, 2016
2answers
I check all the setting but repeat same problem Brightness dims when power is CONNECTED, brightness restored when power is DISCONNECTED please suggest proper settings to reduce this problem?
Hi, also check power options. I have windows 7 and can just type it in and various options are thrown up, try that
7/18/2015 2:10:25 PM • Dell Vostro 1015... • Answered on Jul 18, 2015
Left control buuton, delete and home buttons are not working from today all of a sudden. How do I solve it?
Hi Anonymous, My name is Pradeep and I work for Dell's Social Media Team. Please turn off the system and unplug only the power cable. Press and hold the power button for 15 seconds. Plug in the power cable. let us know the status. Please clean the system air vents using canned air. Here are the steps: 1.Check the vents on the computer to see if they are covered with dust and not allowing heat and air to pass through. 2.Turn off the System. 3.Unplug the AC Adapter. 4.Remove the Battery. 5.Use Compressed Air to blow the dust out of the vents Please restart the system in safe mode and let us know the status. Please go ahead and power off this system and when you power it on at the Dell logo, keep tapping the F2 key repeatedly for 3-4 times this will take you to the system set up. Press F9 to load defaults. Save and exit setup. Pradeep Lokesh Social Media and Community Professional Order Status: http://del.ly/61822hij Download Drivers: http://del.ly/61832hid
7/14/2015 5:35:28 PM • Dell Vostro 1015... • Answered on Jul 14, 2015
2answers
B n and space bar keys are not working
krishna, You can try popping them off and blowing the dust accumulated from underneath. If that does not work you may need to replace the keyboard. Thank You, Dell-Jesse L Dell Social Media and Communities
6/17/2015 7:06:39 AM • Dell Vostro 1015... • Answered on Jun 17, 2015
Key board lock and not working
Look for a Fn key, and note the color. Now look for a symbol that looks like a keyboard. Press the Fn key + the key with the symbol. That should enable the keyboard.
6/16/2015 12:06:24 AM • Dell Vostro 1015... • Answered on Jun 16, 2015
DELL VOSTRO 1015 MEDIA DEVICE NOT FOUND
Hello, You may download the audio driver from the link mentioned below: http://downloads.dell.com/audio/R286583.exe Hope this helps..
3/5/2015 6:05:13 PM • Dell Vostro 1015... • Answered on Mar 05, 2015
2answers
While installing my wireless driver in my dell vostro 1015 laptop i face an error " QMI module not exist? " any help?
On a dell they have either a hardware switch or a ALT-? key combination to turn the wireless on, normally it's a hw switch on the front or one of the sides with an antenna symbol. Look at the color of your ALT key and then look for the Antenna symbol or wifi symbol, Either of them should toggle the power to the wifi card. also you can hit the windows key and look on the right side of the pop-up and find the computer link, right click on it and open properties then Device Manager, look for anything with a Yellow Triangle on it It may say Unknown Network adapter, right click on it and select properties, and then the driver tab, click update driver and explore and find the C:\Dell\drivers or c:\drivers directory and reload your wifi driver. Good Luck
2/21/2015 11:05:33 PM • Dell Vostro 1015... • Answered on Feb 21, 2015
Optiarc dvd+rw ad 7700h ata device not recognizing any devices
CHECK IN BIOS IF THE DVD IS GETTING DETECTED,, IF DETECTED , GO TO DEVICE MANAGER AND UNINSTALL THE DVD FROM DISK DRIVER AND RESTART AND IT WILL FIX IT
11/28/2014 7:44:11 PM • Dell Vostro 1015... • Answered on Nov 28, 2014
How to use my dell vostro 1015 bios i forgot my system password password?
have too get into bios and short the battery. But try 1234 og admin
10/17/2014 12:02:43 PM • Dell Vostro 1015... • Answered on Oct 17, 2014
My touchpad is not working at all
i think it is driver failure so you can reinistall the driver.to inistall use usb mouse or bluetooth mouse? i think it help you
10/16/2014 1:50:11 PM • Dell Vostro 1015... • Answered on Oct 16, 2014
Which fn key controls the touch pad on an asus
Try fn and space bar.
7/14/2014 9:17:06 PM • Dell Vostro 1015... • Answered on Jul 14, 2014
Power
Hi, To change the brightness level you may try following the below steps which might help:
    (1)Click start. (2)Type power options and select the same. (3)At the bottom of power options move the Brightness control from left to right to increase/ decrease the level. Thanks and Regards. Kiran Kumar. #iworkfordell.
7/11/2014 5:50:29 PM • Dell Vostro 1015... • Answered on Jul 11, 2014
Error code 0146 what does it mean?
This is indicative of a hard drive problem: A user may report they receive an 0141, 0142, 0146 or a 0151 HDD (Hard Disk Drive) error on their Dell Desktop or Laptop system. The Hard Drive may still continue to work but there may be other issues that could manifest themselves as an intermittent failure to boot to Windows, a slow system or noise from the Hard Drive. If possible, before carrying out any troubleshooting steps on the Hard Drive, please make sure you have a verified working and up to date backup of your data You could run the built-in diagnostic tool to determine specific HD problems, using this procedure: To run the Enhanced Pre-boot System Assessment (ePSA) diagnostics, perform the steps below:
  1. Restart the computer.
  2. As the computer boots, press <F12> when the Dell Splash Screen appears.
  3. At the One Time Boot menu, press the <Down> arrow key to highlight Diagnostics and press <enter>
  4. A graphical menu listing all discovered devices in the system is now displayed.
  5. Select Hard Drive and click Run Tests to start diagnostics.
6/18/2014 9:10:11 PM • Dell Vostro 1015... • Answered on Jun 18, 2014
I just got a Dell Vostro 1510 running Windows 7 with a wireless mouse and I can't seem to disable the built in mousepad. I go to Control Panel, Mouse, and that is the settings for the installed mouse
Control panel \ system \ Hardware (tab) \ Device Manager \ Find the device and then right click it and disable it.
6/10/2014 1:17:46 PM • Dell Vostro 1015... • Answered on Jun 10, 2014
On 5 sec after off laptops
You could try to start the computer in safe mode, to see if this is driver issue. When starting computer, press down F8 and select safe mode startup. If monitor works in safemode, try to reinstall display driver. Also you could check with external monitor, to isolate where the issue is related to. If external monitor works fine, it might be HW problem with your laptop monitor.
6/4/2014 8:13:06 AM • Dell Vostro 1015... • Answered on Jun 04, 2014
Compatible printer
aNY DESKJET OR OFFICEJET PRINTER .
5/25/2014 8:27:07 PM • Dell Vostro 1015... • Answered on May 25, 2014
0answers
Dell Vostro 1015 Laptop Logo
148 questions posted
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
View Most Popular
Vostro Dell
  • Vostro Dell
Most Popular Question
  • Computers & Internet
