Info answered before here>
Minolta ep 1030 error e1
Sir/Mam,
Your ATDC sensor located in the developing unit or main board is bad. Have you recently had the developer replaced in the machine and did the person doing that use a vacuum cleaner to clean out the old developer if so then the static electricity form the vacuum cleaned destroyed the sensor. NEVER USE A VACUUM Cleaner to remove developer in the developer unit.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Minolta EO 1080 Copier-Error Code C05
Did you do anything to the fusing unit (ie cleaning thermistors or replacing the fuser roller?) That code means you have a temperature problem. It will also come up if your power cord is loose. You can check it by taking off the back cover of the copier and pressing in the trouble reset button while the copier is on. It's a small black button. If the code goes away, you're good to go. If it comes back, you might have to replace some of your fuser components.
SOURCE: EP 1083 service /reset codes
Press on keyboard, stop o stop 1. Press 4 to enter counter mode., the first counter should be the pm, displaying a counter with a negative sign. Press cancel key to reset to 0. Exit service mode by pressing panel reset 2 or 3 times and you should be back in business.
SOURCE: meaning of code C04 ( EP 2030)
minolta cspro1054 turns off once you turn it on and code is c
SOURCE: minolta EP 3000 code M1
Main motor failure to turn. Check the drum and the developing unit is it is rotating easily.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
Same as the E1 bad image unit atdc sensor or the board
Per the service manual
