20 Most Recent
Minolta Di3010 Copier Questions & Answers
Cobao
Your Exit trays hit something did some one leave a trash can or boxes under the exit trays!!!!!!!. Now you need to get a Qualified Konicaminolta tech out to reset the output trays to there proper positions, have to remove the Elevation drive system with out the trayas slamming into the bottom of the finisher, quite complex to do that why I recommend a qualified tech Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/normanj_7893313f0751935f
Di 3010 error code dialta SC 520
First ensure that the right side cover is closed correctly. Check that the two latches that are on the door are not broken especially the rear one. Then fine a paper clip. With the machine on look on the right side of the control panel you will find a small hole. Place the paper clip inside the hole. (Once that is done you can only use that paper clip ever again :) Copier tech humor!) Watch the screen you might see abort code that is OK. When the screen come on that show the copiers look to the left of the screen in the middle a small "." will appears when it does press 3. Nothing is going to happen. Code will come back. Now press the Utility button you should now see a button marked maintenance mode. Press it then press trouble reset. Once again the machine will go though its normal warm up will see the "." do not do anything. Ready to Copy Should appear. If the code comes back do not reset the code your messing with the fuser (The Hot part). It can catch on fire (That would ruin a perfectly good day) so have a technician look at it.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
How can I remove heater unit on Minolta DI 3010 -
There is three electrical connections and 8 bolts two on the fuser (Heater Unit:) Never heard it called that! Before that there is one on the left side looking at the machine from the right side. That removes a small cover. Then there is two to remove the unit above the fuser. BUT Two bolts you must loosen but not remove (They are deep seated just loosen them lift the unit up and out. There are two connectors with this unit upper right corner with red and yellow wires. Once that unit is out of the way the fuse has two bolts below it the you will see to connector on the right side of the fuser and on the left side a 3 wire WHITE plug ensure power is off that connector carries 120 VAC power to the Fuser lamp. With all do respect better get a certified Konica Minolta Tech out to do it. New fuse about 200-300 dollars. Btw, I’m available to help over the phone in case u need at
Minolta di2010 0f32
Have you replaced the developer and drum. If you have did you clear the counters first! Machine works on the information the counters provide if you put new stuff in the machine and do not clear the counters first, the machine works and say's I have old stuff in me increase/decrease as required certain voltages, when you really have new stuff in there copy quality issues and codes. IF you did do it correctly the sensor below the image unit mite be bad, worse case the board the sensor feeds is bad. Once the developer was replaced did you run F8 in service mode. Also does the control panel say replace PC drum then you need new developer and PC drum. Btw, I’m available to help over the phone in case u need at
C0920 c0820
Pull out the first draw and remove any paper from behind it, secondly REMOVE THE PAPER Stored in the First draw That is the paper on the left hand side. NOT A STORAGE LOCATION the extra space is for 11x17 paper not extra storage. Btw, I’m available to help over the phone in case u need at
Minolta_dialta_di3010f_malfuntion_code C0500
Sir/Mam First ensure the right side cover is closed correctly closed also check that the two latches that on the door are not brock especially the rear one. Then fine a paper clip. With the machine on look on the right side of the control panel you will find a small hole. Place the paper clip inside the hole. (Once that is done you can only use that paper clip ever again :) Copier tech humor!) Watch the screen you might see abort code that OK. When the screen come on that show the copiers look to the left of the screen in the middle a small "." will appears when it does press 3. Nothing going to happen. Code will come back. Now press the Utility button you should now see a button marked maintenance mode. Press it then press trouble reset. Once again will go though its normal warm up will see the "." do not do anything. Ready to Copy Should appear. If the code comes back do not reset the code you messing with is for the fuser (The Hot part). It can catch on fire (That would ruin a perfectly good day) so have a technician look at it.
Konica di3510 c0511
To reset you will turn on the machine then take a paper clip end gentle push one end into the tiny hole on the right side of the operational panel the screen will change you are waiting for a small dot to appear on the left side of the screen in middle when that dot appears touch the 3 button. the machine will continue to show the code but now go to Utility/Counter button touch it you will see a new setting called maintenance mode touch it touch trouble reset let the machine go though it routine you will see the dot again let it go. Machine should go Ready To Copy if the code comes back get a tech out to look at it you are messing with the fuser the hot part resetting over and over mite catch on fire (Would ruin a perfect good day:) Hope this helps Btw, I’m available to help over the phone in case u need at
Co511 di3510
To reset you will turn on the machine then take a paper clip end gentle push one end into the tiny hole on the right side of the operational panel the screen will change you are waiting for a small dot to appear on the left side of the screen in middle when that dot appears touch the 3 button. the machine will continue to show the code but now go to Utility/Counter button touch it you will see a new setting called maintenance mode touch it touch trouble reset let the machine go though it routine you will see the dot again let it go. Machine should go Ready To Copy if the code comes back get a tech out to look at it you are messing with the fuser the hot part resetting over and over mite catch on fire (Would ruin a perfect good day:) Btw, I’m available to help over the phone in case u need at
C0960 error code
Manual bypass lift. Located on the right side of the machine. looks like a step well the code indicate that it is not lifting the paper on that tray to get it to the rollers. Check for anything jammed inside if not have technician look at it there is a service bulletin out on that code mite have to have the clutch and accurator re-aligned. Btw, I’m available to help over the phone in case u need at
