20 Most Recent
Minolta EP4000/5000 CS/PRO Copier Questions & Answers
Copies shows: Call Maintenance M2
Hello, the error code M2 means that the machine needs to have maintenance done ( like tune up to a car).. The
only way to clear it would be to reset the counters and the service
tech mode.
11/17/2018 4:25:30 AM •
Minolta...
Answered
on Nov 17, 2018
Copier problem code c0200
check the charging assembly & transfer assembly maybe the corona wire is broken or there is a leak in charging or transfer assembly
2/10/2018 11:05:11 PM •
Minolta...
Answered
on Feb 10, 2018
Showing error code 0046
Fusing motor cooling fan is in op due to dust build up, motor gone bad, or the main control board has gone, to reset open close front door, if it still come back (code) Then remove the back cover after unplugging and clean all filters and fans if one is dirty they all might need dust removal. remove each fan clean with can air make sure they turn properly. Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/normanj_7893313f0751935f
12/26/2015 5:33:31 PM •
Minolta...
Answered
on Dec 26, 2015
Tengo en una minolta el
!st draw lift motor failure, is there a small wrench in the lower left hand corner of the control panel when you initial turn it on, before using it? Touch the small wrench it will take you to another screen, then open the front door and close it. that will reset the machine, Also check to make sure there is no paper stuck behind the draw. make sure sure the paper is properly installed in the 1st draw. Does the the metal plate below the baper in the first draw lift OK by hand? if the code comes back the chance is the 1st draw lift motor is bad worse case the control board that controls the whole machine is bad. just don't use the 1st draw. Try this site they mite have parts.
Precision Roller Printer Toner Cartridges Parts and Supplies Office... Btw, I’m available to help over the phone in case u need at
11/21/2015 9:43:48 PM •
Minolta...
Answered
on Nov 21, 2015
