I have a Craftsmen Snow Thrower 1150 which has a 24" chute and I need to know how to rewind the cable that came undone. The number is 31AH5WTG799
SOURCE: Craftmans Snow Thrower 247887001 Tire Flat. How to Refill.
The tires are probably tubeless type. If the bead is broken ( not sealed to the rim) the tire will not inflate. Taking the weight off the tire will some times allow the bead to seal against the rim and allow tire to be inflated. You can also put a small ratchet strap around the tread of the tire and tighten it up. This will squash the tire and make the bead seal up. MAKE SURE to loosen strap as soon as bead seals and tire begins to inflate. Hope this helps.
