20 Most Recent
Toro Blowers Rake and Vac - Electric Blower/Vac - 51573 Questions & Answers
ELECTRIC blower will not start.
There may be a shorted winding in the motor. Bypassing the breaker may smoke the whole thing. Look in your phone book or online to find a Toro repair facility. They'll have any parts you need
Electrical burning smell
I had one like this. The problem is probably something wrapped around the blower. You may have injested anything from string to a piece of plastic.
Where can I find brushes
If you're Toro electric blower is slowing down, throwing sparks, or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
Toro replacements are hard to find because Toro does not sell them and it is tricky to make you own.
There are Electric Motor replacement carbon brushes on E-bay for all three motor sizes (7 AMP, 10.5 AMP, and 12 AMP) of Toro Leaf Blowers (Toro Rake and Vac Super and Ultra Blower Vacuums)
Search E-bay for: "Toro Blower Carbon Brush"
- 12 Amp leaf blowers Toro Super (Old model 51552) through Toro Ultra (New model 51609).
- 10.5 Amp leaf blowers Toro Old through Toro New model 51573.
- 7 Amp leaf blowers Toro model 51586 and other Toro 7 amp blowers
Snow thrower won't throw snow
the problem could be the snow is to heavy for the motor to keep up, if thats the case you may need to upgrade to a more powerful model or try not to overload it. take it a little slower so the motor can keep up. but try tightening the belt. with your pointer finger push down on the belt it should have about a half inch give, if it moves more than that its too loose and probably slipping under load
Toro 521 snowblower..nn replace gas line to carb,
Or, you can try the easy approach. Take a 1/4" bolt about 2" long and cutoff the head. Force the bolt into the old fuel line on the fuel tank side (after removing fuel tank), push other end into new fuel line, tape the lines together well with electrical tape. Gently pull from one side and push from the other until new section of line comes through. Just did this and it too all of 5 minutes.
Carbon brush for blower toro
I had a broken brush for an electic weed eater. I could not replace just the brush. I would have been required to purchase the whole electric motor. I chose to get rid of it, it just was not worth it. I suppose you may try to find a parts one, good luck. Or maybe see if you can get access to a carbon brush kit like the ones used for industrial maintenance. That may be your best shot, depending on who you know. Otherwise you will probably have to replace it. Sorry.
If really helpful, please rate.
Won't turn on
Some of these have a reset button in a tiny hole in the bottom rear of the unit. Try pressing the reset with a hair pin or a paper clip. then try turning it on again. Hope it works for you.
