20 Most Recent
Troy-Bilt 179cc 24-in Two-Stage Gas Snow Blower 31AS62N2711 Questions & Answers
Steering nut missing
Take it to a small engine repair and they should be able to match the lost one.
To do it yourself you need nut size and thread size as well.
Troy bilt fix
check drive belt
tip it on its nose, ( be sure gas is only 1/2 full or less)
remove plate on the bottom
see if wheel is close to the alum plate
sqeeze handle see if wheel contacts plate
if not adjust cable under handle
How do you do a oil change on troy bilt bronco
Look for a plastic cap with two bumps on it near the bottom of the engine (or a pipe about 4" long with a pipe cap on the end). Open the cap and tip the machine to drain the oil. Set the blower upright and refill with 3/4 quart of oil (24 oz). Check level, add more until the dipstick says it is correct. Usually about 32 oz.
