Hi ever since I got my straighttalk phone line my internet connection is lost. I had the notebook checked, it is fine, I called hughesnet they said I have connection and also have not used up my allowed data usage, can you please tell me which dual band router will work best, also I am in a rural area of southwest Ga. Thank you.
Biggest fan here of the Ubiquiti Line of devices.
The home model of this device is "Amplifi".
https://www.amplifi.com/
SOURCE: Setting up Netgear Wireless-N router
try this plug up a line to laptop to modem to check to see if you can get connected if so then make sure you are on the same network and if so then call comcast to help you setup the laptop wireless settings in sound like the settings online doesn't have the laptop enable to accept the laptop
SOURCE: PS3 NAT type 3 issue
HI, Upgrade the firmware on the router and then forward ports on the router for the IP Address of your PS3.
Let me know if you need any further help.
SOURCE: NetGear NETGEAR WNDR3300 RangeMax Dual Band router
The Netgear wireless router wireless settings need to be configured and the the wireless card in the computer and XBox needs to be configured with the Netgear wireless settings.
Follow these steps. : -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL
3. Enter the router setup login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WAP2
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router.
SOURCE: HN9000 DSL and RangeMax Wireless not connecting wireless laptop
Connect the modem directly to the Computer first and try n go online if the network is not disconnecting frequently and if
everything works fine then this is the no. for the
It's a toll free number call them and they
will guide
you step by step in a proper way.
If you are not able to stay online
with the modem directly connected to the PC then call the hughesnet
customer care 866-347-3292.
Good luck.
SOURCE: just connected router to clear network modem and
Hi, I also have the clear network and haven't had this issue. Did you hook it up per the instructions? You hook the ethernet cable from the clear modem to the phone modem and then hook an ethernet cable to your computer or router. I think it's important to hook up per their instructions, to the phone modem first. You should give them a call, they'll work with you and help you to install everything correctly.
