20 Most Recent
NetGear RangeMax Dual-Band Wireless-N Router with 4-Port Ethernet Switch Questions & Answers
Router only seeing 100mbps on
That would be the correct speed unless it is a gigabit router and you have a gigabit adapter. Otherwise the maximum speed you will get is 100mbps. Odds are your internet connection is far less than this anyway and will not impede your throughput.
Hope this resolves your issue.
How can you use public access on your desktop and
Just having the wireless router without connecting it to cable modem or DSL modem will not allow you to get onto the Internet. The wireless card in your computer/laptop will allow you to get onto the Internet at a free public WiFi hot spot location such as McDonalds, Star Bucks, at the airport.
Also the wireless card in your computer/laptop may allow you to connect into an unsecured wireless router from your neighbors, if their wireless router is within range of your computer/laptop but without their permission to use their Internet, it is considered stealing from your neighbor. They have a set download limit from their Internet Service Provider and by you connecting to their ISP you may cause them to exceed their download limit and they would be charged additional costs for every Mega byte over their limit.
Lost my cd for net gear wireless-N Dual Band
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
I have the Netgear RangeMax
This is a problem for your iphone server not us, you may have to enter codes for the phone to work.Sounds like configuration faults.
I cannot get to the Netgear site. I need to add a
Hello, Thanks for joining Fixya.
I think you meaning the Admin configuration page of router.
First let me know you sure about default gateway address of that router.
If you not sure, open Start Menu> Run , Type CMD, type ipconfig. check what is default gateway address . then type that in browser, I think you will done...
Further result let me know please..
Thanks once again.
My n-router went dark indicating no power. After
I had the power adapter tested and there was nothing wrong with that. It was the unit itself that died. It would have cost more to fix it than buying a new one. I was very disappointed that this would happen after only 2 years. I have since bought a different brand.
I have lost my orange serial number
The serial number should be on a sticker, somewhere on the router itself. If it is not you will need to contact netgear customer support. They will be able to assist you further.
post back if you have any further question's or comment's. Thank you for choosing Fixya!
Netgear wireless n modem router type
You can consider following steps to for the x-box live with netgear dgnb2100:-
a)Get any computer which has the internet access to it , Open a Web browser, and type the router's IP address (The router's default IP address is 192.168.0.1). Click Go.
b)Enter the username and password for the router (Default username is admin and password is password).
c)You will be navigated to router administrator page , you will have a blue/purple column on the left hand side which has the different setting options in there.
c)From the browser Main Menu select Advanced and then the sub-title WAN Setup.
d)Under WAN set up,check the box for Default DMZ Server enter the server's IP address[192.168.0.20] the corresponding box for the IP Address.
e)Click Apply.
ON X-box live:-
a)Open the main menu and under setting's select wireless set up and then select manual setting's , it will ask to enter the following information:-
ssid(broadcast name)
security type(wep/wpa-psk) and password to it
ip address:-192.168.0.20
subnet mask:-255.255.255.0
default gateway:-192.168.0.1
Primary DNS:-192.168.0.1
Secondary DNS:-leave that blank and apply the setting's
b)Go for the connection test and it will have the successful connection.
This Link will be of great help:-
http://kb.netgear.com/app/answers/detail/a_id/1118
I currently have an AT&T Fast Access DSL
The best possible configuration will be to configure the netgear router as an access point.
The following link will be useful:-
http://kb.netgear.com/app/answers/detail/a_id/965/kw/Configure%20router%20as%20AP/r_id/100109
I am trying to change my router supplied by
Sir what you can do is to try the user name as admin and password as the word password both in lower case and then you will have the access to netgear smart wizard from where you can do all the setting's.
Default access:-
username:-admin
password:-password
Laptop drops signal but other doesnt
This issue generally occurs due to the outdated Wireless Driver.
Check for the Updated Wireless Driver for your Computer (in which signal is dropping) and install in the Computer to resolve the issue.
If the Updated Wireless Driver is not available then un-install the Wireless Driver and install it again to resolve the issue.
Good Luck!!!!!!!
Homegroup problems with wndr 3700
The wireless router needs the wireless settings configured and also the wireless card in all the laptops and or computers needs to be configured with the router’s wireless settings so the laptops and desktop computers can communicate with the wireless router.
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
Lost my router connection to my Laptop
Hi. I may be able to assist you. Reset your laptop by removing the battery, and the power cord if you have it plugged in. Leave the battery out for ten minutes. Then reinstall the battery and fire it up. You should be all set.
My xbox 360 will not connect because the WEP keys
ahhhh using a router. You need to use a computer that can surf. Google your router model along with default user and password and ip address. should be a 192.168.xx.xx. open a website. Put the ip addy in the address bar and log in to the router. Wireless Security setting will give you the wep and network name
