Remove your service panel and you will find your tech sheet tucked neatly away inside a plastic keeper in that service panel.
The F-21 on your model is:
F21 F 22 CCU /touchpad/LED assembly unable to transmit/receive data to/from the CCU central control unit
Possible causes/procedure:
1. Check the touch-pad/LED assembly by selecting different
cycles and changing the modifiers and options available to
confirm the touch-pad/LED is responding.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the
touch-pad/LED assembly and Central Control Unit (CCU).
Remove the top cover:
Check your connection for corrosion or soap dripping into the top of the machine. It is advised not to set anything on top the washer that might drip into the controls.
If you need further help, reach me via phone at
https://www.6ya.com/expert/dan_73bbd84fe1d95b61
