20 Most Recent Whirlpool GH6177XPS Microwave Oven Questions & Answers
F7 ERROR CODE ON GH6177XPS
This is a known problem with this unit, and whirlpool has put out a Service Flash out on this. The reason this is happening is Electrical circuit interruption between the L1 and Neutral in the microwave invert circuit. This has to be addressed by a Tech.
DrakeTech
6/17/2014 12:59:59 AM • Whirlpool... • Answered on Jun 17, 2014
Grilling bulb out
hello chris microwave is an american model I found the tube/bulb you looking for is like the picture and called quartz grill tube and can be replace by similar voltage 120 v f5a964d9-0bc4-46a1-adbb-8723896b3c71.jpg
4/8/2014 8:58:58 PM • Whirlpool... • Answered on Apr 08, 2014
0answers
F7 error code
Be the first to answer 2/3/2014 4:07:33 AM • Whirlpool... • Posted on Feb 03, 2014Be the first to answer
2answers
My whirlpool Gr2 microven Model
Sorry to read about your problem.
It seems your have a general failure in the power control or switch failure on the unit. if you unit has power, and things lite. it is more likely you have a control/switch problem,
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
dsddd
6/10/2013 8:57:37 AM • Whirlpool... • Answered on Jun 10, 2013
Can I change the control panel screen? It is very scratched up.
you can do it se the video and use the common sense. God bless you
10/16/2012 4:48:58 AM • Whirlpool... • Answered on Oct 16, 2012
Panel not working
see the information and use with common sense. God bless you. Door is not closed (some models). 2. You waited to long (open and close door to wake it up). 3. Controller is confused (pull plug for a minute or two to reset). 4. Defective interlock switches. 5. Faulty controller or its power supply. 6. Touchpad or controller board contaminated by overenthusiastic cleaning. 7. Defective/damaged touchpad.9_10_2012_12_26_08_pm.gif9_10_2012_12_26_31_pm.jpg9_10_2012_12_27_11_pm.gif
9/10/2012 12:27:39 PM • Whirlpool... • Answered on Sep 10, 2012
The turntable on my microwave spins with the door
probably a defective door switch and/or a door mechanism problem. .
8/4/2011 1:07:38 AM • Whirlpool... • Answered on Aug 04, 2011
Error code F7
Hi drk2676,
This error code F7 means that you have a function key stuck on ERC. You can solve this issue by replacing control board (also called ERC or clock). You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central.
Hope this helps.
Thank you for using FixYa.
6/8/2011 3:34:57 AM • Whirlpool... • Answered on Jun 08, 2011
Microwave does not shut off when door is opened.
It may be a bad door switch or mount, or maybe a relay on the control board is sticking.
First, see our safety info here.
Then we have a helpful file on diagnosing and replacing door switches here.
If that's not the issue, we regularly repair control circuit boards for $39.95, or you can order a new one (part number 8205237) for $203.08 here.
8/19/2010 2:21:29 AM • Whirlpool... • Answered on Aug 19, 2010
Grilling Halogen & Quartz Replacement Bulbs and Paint coming off handle
good day,
hope this link below will solve your problem.
grilling
8/5/2010 2:57:19 AM • Whirlpool... • Answered on Aug 05, 2010
Whirlpool GH6177XPS3 Touch Error display
I've got the same problem and error code. Did you ever find the fix?
6/4/2010 9:58:58 PM • Whirlpool... • Answered on Jun 04, 2010
Touchpad does not work
This is a common touchpad error which we regularly repair for customers nationwide for $39.95 one year guarantee.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
4/28/2010 4:48:12 PM • Whirlpool... • Answered on Apr 28, 2010
Whirlpool microwave model GH6177xps-3.\r\n
Alright since (part #6) isn't a perfect part number, I would believe that you were shipped two metal brackets but most likely a non-metal part broke if anything. If you can take a picture of the part that is broken, then I can tell you what part to order otherwise if you can pick out the part from the following diagram, then you can do it on your own from the following website.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5137483&diagram_id=955883#d955883
You can send a picture to my email at [email protected] and I will post back what part here.
Let me know how this works out for you.
Benjamin
12/13/2009 3:39:21 AM • Whirlpool... • Answered on Dec 13, 2009
Error message
may be u dnt have any service
12/4/2009 7:47:58 PM • Whirlpool... • Answered on Dec 04, 2009
Touch pad not responding
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
[email protected]
11/25/2009 10:20:52 AM • Whirlpool... • Answered on Nov 25, 2009
Have GH6177XPS. Everything works normally. Have
It would be unusual for even a Chinese fan to have failed bushings in that short period.
If this unit has a conventional power supply for the magnetron, the noise might be caused by the magnetic field of a large power transformer. These can have a strong stray field and can cause other sheet metal near them to vibrate.
It isn't dangerous, assuming you don't poke a finger inside, to remove the rear panel and inspect the innards while it is operating. Using something that isn't metal such as a plastic or bakelite spoon (even dampness in a wood utensil can conduct a painful shock), you might try damping the vibration with it. If you can locate the source, you may be able to kill the resonance by applying a fairly large bead of pure silicone (nothing else) to the surface making the noise.
It it seems to be coming from the transformer itself, I would pull the plug, let the unit sit ignored for a couple of hours (there can be charged capacitors inside) then use a finger to press silicone into the transformer's laminations. These were once soaked in epoxy in a vacuum container to **** all the air from between the laminations to prevent exactly this kind of 'rattle.' They probably don't take the time for that any more.
4/1/2009 6:20:00 PM • Whirlpool... • Answered on Apr 01, 2009
Whirlpool GH6177XPS G2 Microwave
Your generator may be putting out a square wave instead of a true sinusoidal (sine) wave.
There is usually a circuit in the microwave which monitors the AC line for timing purposes, and a square wave may not be interpreted correctly.
I would consult the manual or contact the manufacturer or installer.
We're happy to help and we appreciate your thoughtful rating of our answer.
2/17/2008 4:42:28 PM • Whirlpool... • Answered on Feb 17, 2008
Whirlpool GH6177XPS Microwave Oven Logo
37 questions posted
Top Whirlpool Microwave Ovens Experts
ZJ Limited
ZJ Limited
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Whirlpool Microwave Ovens
Most Popular Question
grilling bulb out
  • Microwave Ovens
